Playstation 2 Slim FreeMcBoot + Pad
  • Thread starter Thread starter marculos
  • Replies Replies 5
  • Views Views 1728
M
marculos
Guest
Playstation 2 Slim, Freemcboot 8mb card, 1 Pad, PSU and composite cable.
£25 delivered UK.
Declaring interest subject to the free mcboot working with it and it being in good condition and fully working.
Does the bootcard work on slim? I thought it used an exploit in the PSX hardware on the old revision?
Skickat från min Nexus 4 via Tapatalk
yes freeMcBoot works on the slim up to a certain model number. (goes off to check)
here you go, I ran a PS2 Slim with FreeMcBoot and a USB HDD but is was slow due to the PS2 USB ports being 1.1
If your PS2 is fat model, it is compatible.
If your PS2 is slim model, and has a model number that is SCPH-7xxxx or lower, it is compatible.
If your PS2 is slim model, and has model number of SCPH-9XXXX with date code 8a or 8b, it is compatible. If it is 8c, it may or may not work (depends if built in 3rd quarter of 2008. )
If you have a different date code, you cannot run FMCB as Sony fixed the exploit.
Works fine with FreeMcboot. Tested with an ESR patch game and worked fine As USB is only 1.1 its slow off USB media but fine over LAN.
http://postimg.org/image/9buoovp93/
Hi tested this morning and is fully working if you still need it.
