Wanted Power supply for A3000T
Hello,
I would highly recommend you have someone convert yours to ATX. You can move the guts over and get it to fit in a 3000T power supply case.
From my experience, the 3000T power supplies have a very high failure rate. Even if you get it recapped, they are problematic. I have a spare 3000T power supply that has failed, like my main one. I got it converted and I never looked back, works perfect!
So if you find another working power supply, it will probably fail in the near future... Save yourself the headaches. :)
Thank you very much for the information. My power supply has just come back from repair and it is not working again. I will do as you say. I have an ATX power supply. Can I find instructions somewhere on how to modify it for the A3000T? I can use a soldering iron and a multimeter but I need some advice so as not to damage the Amiga.
I hired someone off of Acills discord to do the conversion. I would join that discord they have a ton of talent that hang out there. I know he had to buy a converter from someone for it and get a certain size atx to work.
