Question about Saturn and backup games
dougal
Malta
I dug out my poor old Sega Saturn. It was having trouble reading discs after being stored in a box for years on end unused, but I cleaned the lens and its working perfectly once again :D
I was wondering if its possible to play backed up discs without a modchip and without the disc swap trick ?
scrappysphinx
Confused retro man
Nottingham
Sadly not on the Saturn. You can region mod it but that will only allow the playing of originals from different regions. You will need a modchip to play backups
dougal
Malta
Ok no problem. It might be modchipped it might be not. I've got no idea. I bought it second hand years ago from a car boot sale.
I'll try loading a backup game and see if it runs or not I guess.
Disc-Swap I will never attempt as I heard its not very good for the laser/motor
Jamma
Suffolk
I got one of those universal mod chips over at assemblergames last year and it worked a treat, pretty much plug and play without the mega soldering of some mod chips.
It was not that much money either, but did work a treat.
danwood_uk
England, UK
Nottinghamshire
Any idea which one? I've got one that needs soldering and have never managed to get it to work, despite cutting the traces and soldering the pads I'm supposed to.
dougal
Malta
I think he's talking about the V3 modchip or something like that. The only wire that needs to be soldered is a 5v wire. The rest is plug'n'play.
For once the soldering seems easy. Not sure where the modchip can be mounted due to heat/space as I have not googled enough info yet.
Jameson
Queensland
I must say that of all of the consoles I have "chipped" over the years the Saturn is the easiest. From memory the V3 simply plugs into the ribbon cable going to the cdrom and thats it. About a ten minute operation to fit.
