a few day ago, I found a video showing a dual port USB riser for the Terrible Fire:
I found a 3D model for the cover:
https://www.thingiverse.com/thing:4936943
I found the github page dealing with an experimental riser
https://github.com/terriblefire/cd32_riser
But cannot find any other trace of it.
I also find the Imperator CD32 riser with VGA/RGB/AUDIO OUT and SINGLE USB:
But didn't find a cover?
And I aslo found the Hefesto CD32 riser with VGA/AUDIO OUT and DUAL USB:
and the 3D cover: https://www.thingiverse.com/thing:3364994
So here are my questions:
I have a TF360 and I want USB, Should I go for USB riser or use adapter?
If riser, Imperator or Hefesto ?
Any shop? Or only when they appear on ebay or direct selling with the creator?
Last question, on the VideoGamePerfection RGB modding page (https://videogameperfection.com/products/cd32-rgb-modification/), they said:
'This modification produces significantly better visual results than the plug and play RGB output options such as SX32, Terriblefire etc. The problem with those modifications is that they route the RGB signal all round the CD32s board, picking up noise as it goes.'
What do you think?
What do you think?
