Quick Question - using LHA's on A500
hoptoit
Portland Oregon
Howdy - our A500 is up and running again but I want to try a few apps that I found online here:
http://amigarealm.whdownload.com/amiga/amitools/tools4.htm
They are all LHA format, which I can open easily on the PC. But how do I make use of them on the Amiga?
I currently have a working link with Amiga Explorer to transfer between PC and Amiga. Do I just drop the contents of the LHA onto a diskette?
Justin
howdy back partner,
do you only have a floppy drive? you may need a LHA decruncher on a floppy.
how are you getting info from your pc to your amiga?
maybe unpack them on the pc then transfer the files from the pc to the floppy?
jvdbossc
HypnusBE
Belgium
Antwerp (province)
lha e appname.lha
If you do not have lha in C download
http://aminet.net/package/util/arc/lha
Run it in ram, copy the right lib according to your cpu to C and rename it there to lha
Have fun, and explain a little more juvukuk has a point there to ask...
hoptoit
Portland Oregon
howdy back partner,
I'm using the null modem serial link with Amiga Explorer to transfer.
I have it sorted out now. I successfully transferred the files from the LHA I wanted to use, I just didn't realize that the app was command line only. I was looking for some fancy icons or something. But I got it to run through the CLI window now
Thanks...
