Why does the Radeon HD driver for 'new' Amiga's cost £34.99?
Seems us retro fans require deep pockets!
The X1000 is not exactly new. Regardless, nobody in their right mind would spend over two grand on a new 'Amiga'. Imagine what kind of an amazing PC you would get for two grand. If these new Amiga's were made by Commodore (if they were still around) and cost around £600 then that would be more like it.
Phantom, Should have been be a big full stop before next sentence
Talking about my initial post btw
Slayer checks his mind 3 times and then decides it's not even worth explaining ;-)The X1000 is not exactly new. Regardless, nobody in their right mind would spend over two grand on a new 'Amiga'. Imagine what kind of an amazing PC you would get for two grand.
They are indeed, I have 1 at each end of this table in FDR4 cases permanently connected by a null modem serial cable, how cool is that to serial capture between 2 AmigaOne X1000s! My 3rd is a backup, it's a long way to the UK you know. I will be swapping out one of these though when the time comes for a change.I thought the X1000 modified Fractal Design's R4 case was a nice touch
you are correct Phantom, to each his own
although a windoze peecee can now run OS4.x, can your 3000+ EUR run Windows as well?![]()
