Mr.Bits45
Raemixx500 - Purple.
$589 AUD for Motherboard.
$65 AUD postage worldwide.
$25 AUD within Australia.
- A brand new motherboard for your amiga 500.
- Well made using high quality components and fully tested with diagnostics, games and demos.
- No custom chips, you will need CPU, ROM, CIAs, Gary, Paula, Denise and Fat Agnus.
- Includes all other chips and 1MB RAM.
- All ports tested and working.
- Supports both Fat Agnus versions 318069-10 and 390544-01 for PAL or 318069-11 and 390544-02 for NTSC.
- All metal film resistors and quality electrolytic capacitors that will last for many years.
- The only parts that aren't new are the 23pin D connectors, power connector and line filter, everything else is brand new.
- Socketed oscillator - 28.37516 Mhz for PAL or 28.6363 Mhz for NTSC. Both included. With only 4 pins holding the oscillator a cable tie is used to secure it.
- A place to add jumpers or a switch to select from multiple kickstarts on one ROM.
- You can also add jumpers or a switch to change DF0: to external and DF1: to internal and vise versa. Giving the ability to boot from external drives like Gotek.
