Replacing a laptop floppy drive help needed
Firthy2002
DF0:NDOS
Leeds, West Yorkshire
I have an old Toshiba Satellite T2100 (I think, it's definitely T21X0 series) laptop.
It works fine AFAIK*, except the floppy drive is cream crackered.
I was thinking about replacing the floppy drive, but as it's a laptop I was wondering if the motherboard would use a standard floppy header or some Toshiba proprietary connector?
Would any donor drive do or would it need to come out of another T21X0 series system?
Justin
Re: Replacing a laptop floppy drive help needed
laptops are a bit of a bugger when it comes to replacement parts you could get a usb floppy drive, it looks like it just a slimline drive but it'll be tricky to find one that fits and it'll all be guesswork.
have you removed your floppy drive yet to see if there are any numbers on it?
cheers, JuvUK
Firthy2002
DF0:NDOS
USB floppy would be no good, the laptop is from the early 90s!
Haven't attempted to open it up to look yet. Only recently realised I had it still (it was hidden under a pile of clothes)!
Firthy2002
DF0:NDOS
Would a serial/parallel drive work out of the box without drivers needing to be installed?
Justin
it would need drivers i should think, do you have internet access on the laptop?
I have one of those Toshiba external floppies here (which I try to convert to an Amiga floppy), but the cost of postage and Paypal clearance will kill the deal even before the agreement. :cry:
Firthy2002
DF0:NDOS
No, I need the floppy drive to install the driver for my PCMCIA network card...
r0jaws
Mondeo Man
Lincolnshire
Worst case scenario, pop the laptop hard drive out and hook it up to your PC via a cheap adapter and just copy the files over to your documents. Replace in your laptop, and bingo!
Firthy2002
DF0:NDOS
I might just do that. Once it's networked, the floppy drive won't be needed anyway.
