resurrecting a dying 486 66 PC
mjnurney
we live as we dream. Alone.
england
Milton Keynes
Ive managed to get old of my 1994 era PC (well similar one to my second PC actually), in all its glory ...
486 66mhz
16mb 72pin ram
Opti chipset
TMC PAT48 Vesa local bus motherboard
Socket 3
2x IDE Hdd
conner 348mb
Seagate 3?? mb
creative blaster CD-rom
cirrius logic video cl-gd5426 vga / ide / serial card - vesa
ISA modem
Soundblaster 16 ISA
Dos & Windows95
Pre Windows95 keyboard.
However it was faulty - PC Keyboard locked.
after some time i eventually worked out that this was a motherboard fault and not the key lock or jumper error and yes - the barrel battery had eaten 4 traces on the mobo. I have cleaned and soldered these back up and bingo it works just fine now. After some considerable time on the net , i have found a jumper diagram....
However the Hdd is very loud and I'm half way through setting up a CF card so i can copy some DOS games over but the damn AT power pack has died...
however it will have an ATX in it tomorrow i expect and i'll try to remember how to set DOS up on a CF (nope fuse had gone , AT PSU back in service)
i can't wait to try and find the drivers for this thing....(found on vogan drivers)
mike...
TheCorfiot
Out in the Wild
Corfu
Excellent stuff mate.
I've been very tempted to do something similar for a while, my first PC was a LocalVesa 66DX2
mjnurney
england
Milton Keynes
The battery almost killed it , just need an AT power pack now buddy.
actually my first PC was an Apricot XT & a Zenith 386 for £100 , hideous but i loved them. However the 486 played Doom and Dark forces :)
Danny.
samaron
Norway
Rogaland
The 486 is a nice computer. Did a project a couple of years ago where I pimped up a 486DX2-66 I have. A real pain to configure, as I went for a setup with two sound cards etc. I'd recommend setting up a startup menu with different settings for the DOS enviroment. Some games can be picky, especially demoscene stuff. Games also sound much nicer with Gravis Ultrasound, if they support it. Fun to see someone want to resurrect these computers, that trace corrosion looks nasty. If you're having trouble with the configuration, I'd recommend heading over to www.vogons.org. They also have a driver archive (www.vogonsdrivers.com), which is very helpful!
sneeker
Manchester!
Nice, my first PC was a 386/40 upgraded to a dx2/66 after a year, before that it gained some ram and a soundcard, then a full tower case just like the mikronik Amiga towers.
mjnurney
england
Milton Keynes
Thanks, all working now.
booting from cf , sb16 drives from vogons and dark forces & crazy cars 3 playing ...
im amazed how many hours vanish with computers....
needed a boot disk, couldn't find a floppy that worked - found one
my new pc doesn't have a floppy or floppy power... So I hot wired the floppy
then , the cf would not boot
changed that , the psu packed in...
all in all about 5 hours to play dark forces ...
excellent :)
samaron
Norway
Rogaland
The amount of time just to get it to work is kind of half the fun. ;) Getting a USB floppy drive is a must when dealing with old PCs. Also a zip drive is very handy, one with LPT for the old PC and one with USB for the new one. But since you use a CF card, I guess it isn't needed.
mjnurney
england
Milton Keynes
Changed the VGA lead too, it has a broken wire - everything has a green tint....but now its nice and crisp.
true , a USB floppy and a working floppy disk is handy. I had hoped to format a CF on a windows7 PC and set it all up and then just plug it in and away you go but that didn't happen.
all i got was Insert boot media error.
i spent about an hour trying to get DOS 6.22 on a 720k Amiga floppy , that didn't work either.
In the end i found a good 1.44mb floppy and ran a 6.22 boot disk program that formats and copies the contents over to it.
I have a USB floppy somewhere....an IDE zip drive too.....packed away somewhere , quicker to buy another.
Aysel
Mansfield
Good work mike... That LED 66 display on the tower brings back some memories :)
Ive been tinkering with the x86 cards in my Risk PC and went through the same trauma to get Dos 6.2 installed followed by two hours reminding myself of the config.sys torment, loading mouse drivers into himem to get the extra 4k needed lol, for some reason Tie Fighter runs better on the i486 cpu card than the i586 o_0
roy_bates
resistance is futile!
england
birmingham
i was going to comment on the green tint in one picture but im sure you must of seen it.
im sure i still have a couple of AT supply boards somewhere for projects if you want one and a floppy drive and a ide harddrive.
mjnurney
england
Milton Keynes
Hi Roy , thanks. the PSU seems fine at the mo. so i will see how it goes...
zinamo
Italy
Aosta Valley
Nice machine! Since I'm quite young, I started my collection with a 486 machine some years ago! I know making dos disks can be painful, just pick up an USB-floppy and Winimage and your life will be much easier :) For example, my system didn't had CD (it is hooked to the audio card) when I set it up, so installing Win 95 with more than 20 floppies required a lot of time! Anyway, once the setup is done you'll have hours of fun with it!! And for the PSU, if it's troublesome, replace it with an inexpensive and reliable ATX model using something like this: http://i.ebayimg.com/00/s/MzIyWDU4Mg==/z/EmEAAOSwYshUanp7/$_12.JPG
Firthy2002
DF0:NDOS
Leeds, West Yorkshire
I tried building a real 486 machine for DOS gaming.
Had a few setbacks so I gave up.
All the kit is still sat there though so I really should try again at some point in the near future.
I have a spare known-good AT PSU if you need one.
mjnurney
england
Milton Keynes
thanks bud, it seems fine now - i don't suppose its been used for 20 years :)
todays fun...
downloaded snooper to tell me how the cpu is running...
some more games and over clocked to 80mhz (75 it says) , however as its a 66mhz heaksink it gets toasty and stops after ten minutes. it seems slow
i need a 486 heatsink and fan - i must of thrown dozens away over the years :)
Ive ordered a CF front panel for the CF and hopefully i can get the CD-rom working too - it have encarta95 in it :)
and then Windows 95 of course and a bit of web surfing.
Youtube vid of doom running at 66mhz (slow)
http://youtu.be/h6bURs1vC3k
keropi
Ioannina
heh! I just realized that I use the exact same baby-at mini tower case for my retroPC :LOL:
what are the odds :D
the "00" in the mhz display stands for 200mhz, hosted inside is a pentium 200mhz mmx build.
mjnurney
england
Milton Keynes
nice case mister :)
, i don't have a blank but a CF to IDE adaptor is going in the 5.25inch bay..
I've now fitted a battery and tweaked the cache setting and it flies .... quicker than i remember the 66mhz being.
Dark forces flies now as does Doom , some classic DOS games to try tonight then.
even Quake plays - a little sluggish but not bad.
SaviorX
VCCUG
Canada
Calgary, Alberta
if anyone is interested, i have had good success getting IDE DVD drives running under DOS with one of these drivers...
mjnurney
england
Milton Keynes
thanks i'll keep that handy but my sb16 has a cd interface - not tried it yet
