Hello!
It's been 11 years since I sold my amiga 4000, and I just recently bought an amiga 1200 again. The plan is to use the amiga for coding (apps and demo), and as such I've bought an accelerator card.
Next on my list of Wantings is the following:
1) Compact Flash as replacement for a HD.
- Question 1:
Does it matter where I buy the device from? There are cheap connectors from dealextreme, but not sure how reliable they are? Anyone else with experience from this place, or perhaps specifically with this CF adapter.
http://www.dealextreme.com/p/compactflash-cf-card-to-ide-hard-disk-adapter-card-ide-44-10310
Amigakit has a complete kit for 32 Euros, which seems like <snip>, unless they are more reliable than dealextreme's products. I obviously want to support the amiga dealers out there, but if the price difference is large for a generic product, then I don't see the point of buying specifically from amigakit. Perhaps someone can enlighten me on this issue (pros/cons)?:
http://amigakit.leamancomputing.com/catalog/product_info.php?products_id=883{45}129{48}134
- Question 2:
Which file system should be used today? When I left the amiga scene 11 years ago, there were a number of file systems being developed, and I seem to recall a few of them being mentioned in threads. What are the pros/cons of the file systems today? Does it matter which type of medium I use (CF/HD etc.)?
- Question 3:
Next up is the question of network connection between the Amiga and my network. Amigakit has two options; wireless, and wired. Does the wireless support WPA2? Any problems with the wireless network card in general?
- Question 4:
PCMCIA adapter for compact flash cards (large file transfers, party transfers etc). Same question here regarding amigakit vs dealextreme, anyone with experience?
- Question 5:
Hard disk size. If I remember correctly, the amiga hard drives had a limit at one point (4 Gig). Is this still true or can aos 3.1 (I'll be using this) use larger disks (CF/HD etc)?
- Question 6:
I need a scandoubler!!! If you happen to be Jens reading this: Get your arse in gear! I want my Indivision Aga MKII
I appreciate the help!
- Question 1:
- Question 2:
- Question 3:
- Question 4:
- Question 5:
- Question 6:
