my dremel has died. brushes won't revive it so I've binned it!
so ...buy another! ahhh i forgot how expensive they are and for a tool i use once every six months..
after a quick search on everyones favourite auction site (
) i found a compy of a dremel tool for very little money - why not said i.
I've been using it for a couple of days and i have to say that its very good, the quality isn't brilliant and its no good as a drill (it stops when pushing) but it is a grinder after all.
it has selectable speed from slow to very fast and a power button on the body. it is almost a direct copy of the dremel at less than half the price. while its not as well made as the dremel , for a hobby person it will do.
however if you are heavy handed or in need of better quality - buy a dremel, for cutting up Amiga cases or shaping thin steel it is just the job.
mike.
Multitool Dremmel Style Hobby Tool + 105 Piece Acc
135W MOTOR AND COMPATIBLE HOBBY DREMIL TOOL ACCESSORIES SET 105 PIECE
For: Cutting, Carving, Sanding, Grinding, Cleaning, & Polshing
1 x 12.7mm Drum Sander
4 x 12.7mm Coarse Grit Drum Sanding belts
5 x 12.7mm Fine Grit Drum Sanding belts
1 x 9.5mm Felt Polishing Tip
1 x 3.2mm Set Screw Mandrel
1 x 3.2mm Screw Mandrel
1 x 9.5mm Aluminium Oxide Grinding Stone
1 x 15.8mm Aluminium Oxide Grinding Stone
1 x 25.4mm Felt Polishing wheel
6 x 12.7mm Felt Polishing wheels
1 x 9.5mm by 25.4mm Dressing stone
1 x 10.3mm Silicon Carbide Grinding stone
1 x 19.8mm Silicon Carbide Grinding stone
3 x 31.8mm Reinforced Cut-off Wheels
36 x 23.8mm Cut-off Wheels
1 x 19mm Wire Wheel Brush
1 x 12.7 Bristle Cup Brush
36 x 19mm Medium Grit Sanding discs
2 x 3.2mm High Speed Cutters
Polishing Compound
Max Operating Speed Cutting ,
Grinding Sanding 35,000 RPM
Max Operating Speed for Brushes .... 15,000 RPM
mike.
Polishing Compound
