Rogue fans check this out!
  • Thread starter Thread starter klx300r
  • Views Views 1213
klx300r
Canada
Ontario
denis2342 over at amiga.org has fixed some bugs and added a few cool changes to Rogue as noted below great.gif
bugfixes:
compatible with fastmem now
rogue -s now can return to the shell
scroll of wild magic is now immune to potion of discernment (clearly the developers wanted it this way)
fixed the three typos (thuderclaps, missle and instructiuons)
scroll of wild magic is now shown with its name after declining to use it
if you identify an item where you have two of it (or more) all item descriptions get updated.
setting the macro now works (shift-f)
scroll names do not end with a space anymore
update screen titlebar after restoring a game to show rank and stuff
fixed creation of gold in _create_obj (wizard mode only)
the ability to see the invisible actually works now
changes:
show_map and show_passages code is now reconnected (wizard mode only)
food_left and show_inpack is added (wizard mode only)
fastmode now has a small pause added so you can still see the player
bitmap handling now uses only 4 big memory allocations and not 288 small ones
print actual score with color in topten list (seems only to work in v40)
reactivated the beep function
added the shortcuts to the command menu
hiding strength,maxhp and xp in the highscore file (can be overwritten by long names)
limited the repeat count to 99
check out the thread to download the ADF here: https://forum.amiga.org/index.php?topic=75893.new#new
Crashdisk over at EAB left this message on the thread I created there:
"I noticed 2 unusual things :
- you've moved the system-configuration file to the S folder. This is the wrong place for the configuration to take effect. Any particular reason for doing this?
- The "stack 10240" command is never executed because the stack file is a ... virus (BGS9). as the stack space is not increased, this is not expected to cause any problems in game operation?"
update: I have left a message for denis2342 over at amiga.org so he's aware of the issue and in the meantime Crashdisk over at EAB has removed the virus and the new adf is in The Zone over at EAB
