RTC battery replacement
RedDaemonFox
Amiga's enemy is my enemy!
United States of Hell
Melbourne, FL 32901
If ever wanted to add an RTC battery to a miggy, should I get a barrel Ni-MH (which doesn't leak apparrently) or a coin battery adapter?
Kin Hell
U.K.
Cornwall
Re: RTC battery replacement
@ Dreamcast
It's a Cell battery m8. No leakage what-so-ever. If ever the battery dies, replace it. This depends on the correct Cell battery circuitry being installed in the first instance for the specific Miggy. Some earlier models do not permit a straight swap, as you would end up boiling the Cr battery. ;)
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
That is the only problem with the type of battery I've fitted. It's soldered in so needs desoldering when it eventually dies - that's if I don't die first :woot:
The other way with the holder, diode and cell battery may be better. Because at least you can change the battery when it goes flat :thumbsup2:
Dave G 8)
RedDaemonFox
Melbourne, FL 32901
an what about the Ni-MH on amikit? can those leak even though they aren't ni-cad?
