Sold Samsung and Nec 3.5'' Floppy Disk Drives
  • Thread starter Thread starter darefail
  • Replies Replies 12
  • Views Views 815
darefail
Dare Fail ?
Athens
For sale are 4 Samsung and 4 Nec disk drives, modified to work with Amigas.
Capacitors have been replaced with Nichicon or Rubycon ones.
Tested with some original games, track loader games and Xcopy.
Tested with DD disks only.
On the left is the Samsung SFD-321B, from top
1. FSB1 sold outside Amibay
2. FBT2 sold outside Amibay
3. FBT3 sold outside Amibay
4. FBT5 sold outside Amibay
On the right is the Nec FD1231H, from top
1. 9/2004 sold to awakeningstar
2. 10/2006 sold to awakeningstar
3. 11/2006 sold outside Amibay
4. 5/2008 sold to awakeningstar
I am asking 30€ 20€ for the Samsung and 10€ 20€ 30€ for the Nec, plus shipping costs through Paypal as F&F.
Thanks.
Edit: on sale elsewhere
EDIT: Is this 30 per drive?
Also do any have the capability to with in high-density mode on an A4000D?
Thanks.
(Interest withdrawn here)
Thanks.
Yes it is 30€ per drive and they cannot be modified to work as HD drive. They can only use HD disks, even though I have not tested with any. 99% they do work.
Would you please:
1 - explain the differences between the two brand floppy drives listed (and model part numbers if also different models are listed);
2 - what have been the alterations performed to each drives;
3 - what tests and types of floppies supported (DD, HD) for each of the drives listed;
Samsung drives has the RDY signal available on the pcb. So with the modification you have a 100% Amiga compatible drive.
I have a lot of drives modified for amiga but some of them cannot run some original games or demos.
The Nec drives that are listed could run these games, so I put them up on sale.
The other drives (Sony or mitsumi) can run 95% or more of the games but I decided not to sell them.
About the models.. There are no differences. I just mention it.
All drives are tested with DD disks only. If interested I can test them with HD disk when I have some.
Can you see if the NEC drives support HD and DD floppies
(Marked as sold/completed by livewindarefail)
If I understood the NEC floppies are able to run 100% of all Amiga sw and the Sony and Mitsumi floppies can run only 95% of the Amiga sw
Correct ?
If correct then I take all 3 NEC drives
