SATA and A4000
  • Thread starter Thread starter Templar
  • Replies Replies 11
  • Views Views 2310
I bet yes, i used a similar on a pc, it just converts the SATA to IDE.
Chris
I dont see any reason why it shouldn't work.
Try asking Amigakit
At least make sure it's compatible with more modern SATAII drives. They should still be around a few years yet, but the original SATA are now virtually obselete.
Isn't SATAII backwardly compatible with the slowed SATA1? When you normally connect an SATAII drive to an SATAI controller it works, but as the slower speed.
Apparently it's possible to get SATA-I controllers that don't support SATA-II disks. I've never come up against this, but the Intarwebz claims it can happen. The standards are supposed to be backwards and forwards compatible, but whether someone's implementation is is another matter. :-)
Thanks AndyLandy. :)
@ phantom
My pointing out this matter to you RE: compatibility of drive technologies, is only to save you any grief, should you decide to take this route. - Check it out first. ;)
I got the adapter yesterday.
I installed it now in my A4000 with a SATA HD and a SATA DVD-ROM, but my Amiga recognizes nothing. :(
Any ideas? :help:
SATA
SATA
Hi phantom,
I have a 800gb SATA disk in my A4000D.
I can't boot from it, but I'm using it as a slave and must boot from the IDE.
I'm using OS3.9 and have these lines in my user-startup:
mounter u=1 >nil:
mounter u=0 >nil:
Speed is not very good, but works well. I'm using sfs.
:D
