Sold SBC (Single board Computers) for ISA slot (A2000)
Tahoe
Collector Extrodinaire
The Netherlands
Wilnis
I have two Single Board Computers that connect to the ISA slot in any Amiga. A2000 prefered, or else you need to isolate the PCI slot.
They were both bought as barebone/NOS, added CPU's and memory but the combinations have not been tested. They are basically full PC's on a single card, this way you could have a PC running inside your 2000 and use them simultaniously. However; there is no interaction between the two, they are NOT bridgeboard. They are however Pentium III based and have onboard VGA, network, IDE, Floppy, Serial, PS2. You can create your own interaction using a Siamese (for instance) or install Windows + terminal server and connect using rdesktop from your Amiga! :)
First is a Robo 678, the second is a Peak 670. They come with some port extenders.
Asking for both cards in one sale: € 30,- + shipping
Postage rates here: https://www.amibay.com/showthread.php?43472-Dutch-Postage-rates weight should be over 2KG when properly packaged!
