I got two of these Scala MM boxes from when Scala went bankrupt.
I have taken the box apart to clean and check everything inside. It also nice to be able to document everything inside the box as well. I will image the harddrive too.
Inside the Scala MM box there is a CD32 and a SX1 expansion with memory and a harddrive. There is also a standard off the shelf power supply.
All needed ports have extension cables to the back panel.
