I acquired a SCART lead from a member on here a while back that was described as 'not working'. Tonight I thought that I'd take a look at it and hooked it up to an A500+ and tried it on a portable TV.
I got a blank screen, but if I briefly changed the channel and switched back to SCART I got a brief flicker of a colour boot screen.
The cable is wired for both RGB and Composite as per this diagram.
Pin 17 (Video Ground) is connected to Pin 18 (RGB Blanking Ground) via a short jumper wire and there are no capacitors or resistors at all in this cable. Pin 8 (Switch +12v) is not wired up on this cable.
So, this is one for the SCART gurus out there. Is there anything unusual about how this cable is wired up and more importantly, is there anything missing that should be there? I am wondering if the RGB lines should have pull-up resistors on them.
I think that the brief flash of colour screen I see is possibly the Composite signal but it may be being over-ridden by the RGB lines.
I also know that SCART leads and Amigas can be a family sized can of worms, but I am open to suggestions about this one.
