Gunstarrhero
SD/Micro sd Memory Card to 2.5 44pin IDE Adapter Reader For Laptop NEW
can i use this on the amiga instead of cf? which cf would you recommend? i have 44 pin ide cables, i want to run 2 cf cards on one interface, that can be done cant it? the other reason is running a cdrom drive and a cf flash on one interface.
im pretty sure i can set slave/master on the cd, i know i can on the hdd. im looking to move to hardrive out and replacing it with cf. i wanted one boot cf and one all purpose access read/write.
if i can go to sd id rather go to sd, i know everyone ive seen on you tube has been using cf.
i also wanted to know how difficult could it be to transfer the os to the cf or just install from a cdrom drive. the cdrom drive is a dvd/cd-rom rw +/- it is ide, 44 pin. i have os 3.5 and want to use it instead of 3.1
any suggestions?
i found this:
StarTech IDE2CF 40/44 Pin IDE to Compact Flash SSD Adapter 1 x IDC Male
all of my ide cables are 44pin female. i know this solution would work, i want to know if it is compatible with the amiga direct, or do i need some type of driver?
any suggestions?
i found this:
