DBloke
Sega Activator boxed
£40 + postage, (Will be expensive as its very heavy), can be picked up
What you have here is a bit of gaming "what", Segas experiment into active gaming, did it work?
Well not really it is a bit arsey to use, might as well play on a treadmill.
This is an American accessory (big give away is the mention of the band "Genesis" on the box)
Played it for a bit, then chucked it in "Ye cupboard of stuff" (Bit like the Wii)
Now the bad news.
The tape has broken a bit, its sleeve is also a bit dirty, this isn't so bad as the instructional video is viewable on Youtube in all its 90s cheesyness
http://www.youtube.com/watch?v=ql-UZv3AS-E
Two of the connectors don't lock together. this isnt so bad as they can be taped together if you ever want to play on this
Its NTSC!! Needs a stepdown to get going, plug it into a normal Megadrive plug at your own risk, it comes with the US plug
Its a bit s**t,
It don't like bright lights over head, tried to stick it out at a retro games event in Sheffield a few years back with no luck
I haven't used it for a few years and as I no longer have a step down converter I cant test it so its sold as seen, but how often do these come up in the UK?
