Should I remove RAM SIMMs in my A4000T?
  • Thread starter Thread starter JHanna
  • Replies Replies 2
  • Views Views 273
JHanna
Northern Ireland
I have a BFG9060 with 128MB of RAM.
I believe this is the fastest way to access ram, being directly on the CPU card.
With that in mind, should I remove the onboard SIMMs on the motherboard? (Apart from the 2MB Chip RAM - I assume I need that even with a RYG card fitted.)
Thanks.
Leave it. You CPU card ram has the priority, and thats what amiga will use first. If you will run out - your 16 will be used :)
