Sold Single Board Computer for the amiga
AmigaDigital
The Netherlands
Deventer
For sale
Protech ProX-F501LF-P0204-G1A F501LF-VXDJ 17-106-050110 CPU Board ( 1,8Ghz )
Protech Socket 478 Pentium M support,
VGA, Sound, Single 10/100Mbps LAN, Single 10/100/1000Mbps LAN
Features:
Intel 855GME/GM Chipset
Winbond W83627HF I/O Chipset
Intel 82568EM and Intel 82551QM Ethernet
Auto detect CPU Voltage
Intel Pentium M CPU
Built-in CPU
Internal Sound Buzzer
test this card into the amiga 2000 , works great
Price 275,- euro incl. shipping
Sorry, out of curiosity, what is it? Something like C= bridgeboard ?
it is a single boarde computer , a pc then on a card , i have test this into myn a2000 on the isa bus and then you got the amiga and also a pc in one case , it is like the a2286 , but this is a pentium pc card
Question does this card get its power from just the ISA slot with no additional power plug. What about any drivers needed..
yes when you put the card into the amiga the card get power from the isa slot , and driver , the most drivers got windows , and when it need a extra drive it can be downloaded from internet , the card got also a atx connector for power up the card as standalone
Using this SBC there is 0 sharing between Amiga and SBC except power.
Seperate Video
Seperate mouse/keyboard
Seperate sound
Amiga Janus software does not work with this as it is NOT a bridgeboard, just a SBC using the mechanical card slot in your Amiga.
yes there are sound on the card , here you have more info what this sbc has
Ethernet ChipsetIntel 82562
System ChipsetIntel GM45
Video ChipsetIntel 855GME
BIOSPhoenix-Award PnP BIOS with VGA BIOS
Bus InterfaceISA/PCI (PICMG Spec). PPCIBus optional for PPCI Daughter Board
CacheBuilt-in CPU
ChipsetIntel 855GME/GM Chipset with ICH4, FWH
CMOSBuilt-in ICH4
CPUIntel Pentium M CPU
Dimension338.5mm x 122mm, 13.33" x 4.8"
DRAM2 x 184-pin DDR DIMM up to 2GB
FDD Interface1
Frequency1.3~1.8GHz & up reserved
Green FunctionControlled by hardware & software
Hardware MonitorVoltage, CPU temp. & cooling fan
Humidity20~90%
I/O ChipsetWinbond W83627HF
IDE Interface2 x EIDE (UDMA-100)
IrDA1 IrDA(SIR)
KeyboardMini DIN connector & external connector
LANDual Ports, support Wake-on-LAN, Intel 82562EM and Intel 82551
MouseMini DIN connector (selectable w/keyboard/Y-cable)
Operation Temperature0 C~ 60 C , 32 F~140 F
Parallel Port1 x parallel (SPP/EPP/ECP)
Power Requirement+5V, +12V, and -12V
Power SupplySupport AT/ATX power
ProcessorIntel Pentium M
Serial Port2 x 16550 UART, COM2 for RS232/422/485
Shock30g, 11 msec duration, half-sine shock pulse
SoundAC'97 Codec
SpeakerInternal buzzer
SSD1 x Compact Flash Slot
Storage Temperature-40 C~ 85 C, -40 F~185 F
USB4 x USB 2.0
VGABuilt-in Intel 855GME, supports CRT, LVDS, (18/24-bit), DVO and dual display
Vibration2.5g acceleration over 5 to 2000Hz sine
VoltageAuto detect
Watchdog0~255 sec. Watchdog Timer selectable w/Reset/NMI
  1. akivela
