SOLVED - Help for a Hitachi IC35L060AVV207
genny_flick
Italy
Bari, Apulia
Hi! I have found this hard drive, used very little. It's a ATA 40Gb RPM7200. I want to use in my A4000D with kickstart 3.2.2 (47.111) and BFG9060 with a LC060 CPU. System is a rock stable. I partitioned it without any problems, the boot one is 3GB, the second one is 8GB, I ignored all the remaining space, I don't need it at the moment. I installed PFS3aio and copied all the contents of the old hard disk without any problems. It shows me without any problems in the early boot menu. The problem is that the system doesn't start, it just remains a black screen with no activity. If I connect it as a slave together with the previous hard disk but select it as a boot device, it starts without any problems. I tried different jumper combinations with no luck. I can't get it to work as a master. Any ideas or help?
I have discovered drive have problems with PFS, using SFS all it's resolved.
Thread can be closed.
