Spectrum 128k +2 (Gray) - 78S05 Power Regulator Replacement
wmsteele
Scotland
Renfrewshire
I have a very hot running +2 spectrum, having searched everywhere for a suitable 5v 2a switched regulator without luck would THIS make a good replacement for the original 78S05 regulator?
If it is suitable how would this be connected to the three points of the existing 78S05 (once removed) :help:
Or, can anyone recommend a suitable (UK, in stock) alternative.
Many thanks, -Will
TheCorfiot
Out in the Wild
Corfu
Hi Will
The 78S05 is a 2Amp device so it's very suitable for the Soectrum +2
I would be very hesitant to add a switch mode regulator as it may cause screen interference.
wmsteele
Scotland
Renfrewshire
The existing 78S05 is still fully functional... the motherboard has been transplanted in to a small custom case (+2 minus tape deck!) where the original heat-sink wont really fit (although I have taken the hacksaw to it!). This has resulted in alot of heat building up in the case, that's what sent me in search of a replacement. If a switched regulator isn't as good idea (don't want to cause any display issues) it there an alternative, what about a higher rated regulator?
What about... 78T05 (5v@3 amp output)
roy_bates
resistance is futile!
england
birmingham
just bolt the regulator to a thicker piece of aluminum,job done.
thats what i would do anyway.
