Hi All,
This is probably an unusual configuration - hopefully a couple of you have the same issues, and I'm sure Zetro will know what I'm on about....
I have a 128 +3e with Zeets 8bit IDE adapter - it works perfectly, reading /writing CF all day no probs.
I also have a DivIDE plus, which also works with the +3e no probs.
What I want to do is to be able to copy from a CF attached to the internal IDE to the CF attached to the DivIDE plus - and vice versa.
The problem is, I cant seem to find any O/S that enables me to write to both - it's either one or the other.... residos seems a solution but I can't quite seem to get there....
Is there a solution ?
Helllllllllpppppppppppppp!!!!
(and thanks)
(and thanks)
