Closed STFM w/ 1mb RAM / Re-capped Video&PSU / Floppy serviced
  • Thread starter Thread starter mzry
  • Views Views 397
mzry
Rating - 0%
0   0   0
West Midlands
Hi all,
I recently finished refurbishing a nice STfm machine.
(Located in UK)
Specifications:
* C070789-001 Rev C Motherboard (UK keyboard, UK 240v PSU)
* TOS 1.02
* 1MB RAM (Enough to play almost every game ever produced)
* Fully cleaned & re-capped DSP-508a PSU
* Fully cleaned & serviced floppy drive
* Re-capped entire video circuitry & shifter capacitors
* Casing fully dismantled & washed in HOT soapy water & detol disinfectant
* Keyboard also fully dismantled & washed as above, plus PCB & ports serviced/cleaned
* Old floppy cable removed & new IDC header installed
Only thing that isn't perfect is the floppy case-hole, which has been cut-out to accept regular sized drives. This is fitted with an Atari original Epson drive (which runs really nice, quiet and reliable) But at least you can easily install a Gotek if you want, the hole is quite neat.
Extensively tested for hours using Diagnostic cartridge, floppy drive exerciser, gembench & Frontier loop.
Asking: £150 & £10 postage (UK, locally) International calculated based on destination
cheers,
Overview:
Click image for larger version  Name:	3. main side.jpg Views:	184 Size:	107.9 KB ID:	2405458
PSU re-capping:
Click image for larger version  Name:	4. psu recap.jpg Views:	185 Size:	124.4 KB ID:	2405460
Floppy servicing:
Video and shifter circuitry recap:
Click image for larger version  Name:	6. video circuitry recap and floppy header.jpg Views:	183 Size:	135.9 KB ID:	2405462
Motherboard overview:
Re-assembling:
Operational diagnostics:
Click image for larger version  Name:	12. sysinfo.jpg Views:	185 Size:	116.5 KB ID:	2405464
Forum proof of ID:
