I have 2 Subway USB-Controller for sale
Technical data:
Software:
Package contents:
System requirements:
Each Controller 200.- € + (s+h) + paypal-fees !!!
CU,
AC
Technical data:
- compatible with USB 1.1 and USB 2.0 specification (no highspeed mode)
- integrated 4-port hub
- all ports are protected against overvoltage and short circuit
- integrated power management on port by port base
- power saving 3.3V technology
- compatible with all 68030/040/060 and PPC turbo cards
- no mechanical problems with Amiga 1200 bus boards
- compatible with all Amiga 1200 tower housings
- standard Amiga 1200 clockport connector
- works with all Amiga 1200 compatible clockports (the A600 memory expansion A604 even features a dedicated clockport for Subway with 60% speed gain)
Software:
- integration into AmigaOS via system conform drivers
- comfortable control of commodity driver by hotkeys
- driver for USB mouse, keyboard, serial and parallel interface
- further drivers (webcam, digicam) also by third companies under development
Package contents:
- 1 Subway USB controller card
- 1 10cm clockport flat ribbon cable
- 1 holding plates with two USB connectors each
- 1 detailed installation manual
- Amiga OS 3.1 or higher
- Processor 68030 (25 MHz) or higher
- 100% compatible Amiga 1200 clockport
- power supply with 2.0 Ampere minimum on 5V (each used USB port will use a maximum of 500mA, depending on connected device)
CU,
AC
