Hi all
I'm about to get an Amiga once again, and I realize now that at that time, the whole idea of using an lcd was scifi. Since I will hook it up to a monitor, I was wondering which solution would fit my needs (play games and use workbench on a 1200).
I've done some research, and I found that the scan doublers/flickerfix are what I need. There is one internal, called indivision, which is still sold today, but the price is almost half of what the base 1200 would cost
I understand that it is a good product, but at the same time it cost less to just buy a monitor that support 15KHz at that point.
Then I found 2 other solutions, which are external: one is a box, used as switch for PS2, Dreamcast and so on (they sell it on amazon, it is generic brand; was not able to find any relevant data about the maker); it has an analog RGB in, so I assume that I can use an adapter from the DB23 to DN15, and then plug it into this box and then to the tv via RGB connector...I do not have the amiga so I can't tell if it would work, but I have the box, which I use for my old game systems, so I can give a try as soon as I can get an amiga.
The second solution is a card sold on various places, like ebay, called gbs-8220; which is a card made for arcade cabinets, to replace the CRT monitor with an LCD. Heard that it is pretty good.
Is there any other alternative, to hook up the 1200 to a modern LCD monitor? (mine has the VGA in and the DVI in, samsung sync master B2330) Or this is all that is available? Internal or external makes no difference to me (I have other computers so I can use it with any of them, if it is a generic solution); I just need to be able to work few hours on it without have my eyes bleed, and play some games too.
Thanks!
Thanks!
