Super Hot kickstart roms
Marc
Essex
Hi all,
Is it normal for kickstart roms to get super hot after a few seconds? If not any ideas what may be causing this?
stachu100
Poland
mazowieckie
It's not normal...
Check +5V line, but I don't think it's the reason.
Are there original mask ROM or EPROMS?
scrappysphinx
Confused retro man
Nottingham
i once plugged a kickstart rom in back to front and it got hot and smoked within around 30 seconds
Marc
Essex
Upon investigation the roms are plugged in the wrong end of the socket!
stachu100
Poland
mazowieckie
Yes, this is the only explanation - they are burned and dead instantly if inserted incorrectly.
Marc
Essex
Instantly dead?
That doesnt sound good :(
---------- Post added at 22:37 ---------- Previous post was at 22:28 ----------
Whats the minimum thats needs to be connected before an A1200 mobo will boot?
scrappysphinx
Confused retro man
Nottingham
i would imagine, scart/rf to see bootscreen & power?
however if no floppy drive is connected booting will usually take longer so you may need to give it a good 5 mins
stachu100
Poland
mazowieckie
About 30 sec if nothing is connecter (no HDD, turbo board, ..).
But the chances that ROM's survived are less than 1e-9999999999 :(
Marc
Essex
I have some other ROMS I have tried. Can't get anything out of either of these boards. Buy they were given to me as dead.
Zetr0
Ya' Like it Retr0?
@wasagi
I am nearly done with blankstares motherboards that I promised him a while back.
it you want (and pickup return postage) I can have a look at them for you.
Marc
Essex
Wow Thanks. Well I have two here. If I pay the postage/return, if you manage to fix one you can keep the other? How's that?
arnljot
Dad, gamer, nerd, amigian
Oslo
Oslo
Hot ROMs, yes I've killed ROMs in an A1200 that way. You'll have to try with new ROMs, then you most likely will be fine if the board was working to begin with.
Zetr0
Ya' Like it Retr0?
Sounds like a fair deal =)
hit me up on PM and we can make it happen
please be advised I do have two other jobs that need attention first =D
stachu100
Poland
mazowieckie
From legal point of view you can use EPROM's with copy of your KS version that was damaged. Of course you must have dead ROM's; you cannot sell it nor throw it away.
It's sometimes cheaper than buying new KS ROM.
Marc
Essex
Will do, Thanks :) One of them appears to have some work done to it as there is a wire running from the budgie chip elsewhere on the board (timing fix?)
Thanks for that info :) I'll keep hold of the roms.
