suspecting indivision aga
jvdbossc
HypnusBE
Belgium
Antwerp (province)
I get no display after long amiga usage in my A4000, putting the machine off for 5 minutes, and without touching the machine, the display work's again.
I already did the resistor fix mentioned earlier. Who has the same probs?
jvdbossc
HypnusBE
Belgium
Antwerp (province)
solved probably
solved probably
Ok here it is:
1) The mediator 4000DI busboard is in my hones opinion to close to the indivision aga.(n)
2) running with an open case, meaning no airflow(n)
I did not have a fan small enough to blow air in the two holes of the indivision aga, creating in and out flow.
But I glued a fan as close as possible creating airflow between the busboard and the aga, stressed aga with 64 colors workbench a bit, running one hour, and the machine reboots with a display image!(y) So the error is not reproducable, meaning probably fixed.:nod:
---------- Post added at 18:59 ---------- Previous post was at 18:57 ----------
I cannot feal any heat on the aga card anymore so.
My personal idea is that getting an 060, putting the colors higher, running highfx is a little to much work without proper cooling.
