This is a bit of an odd one I've had lying about for a while.
Clearly it's a Tatung Einstein but seems to be a special build for the National Telephone Exchange according to it's badge, The firmware was also non standard.
She has been fully stripped down, repaired, cleaned, rebuilt and fully tested along with installing the official 1.2 Tatung Einstein MOS.
Although in great cosmetic shape and condition the top cover is missing two plastic inserts which usually clip onto the Black faceplate at the front however it is screwed in place as per normal.
Has a single 40 Track double sided 3" drive which has been cleaned and fully tested, it's very easy to add additional external 3.5" drives to this machine thanks to the 34 way edge connector for easy software disc creation, also compatible with Hxc Floppy Emulator.
Alternatively you can use the einSDein adapter by Charlie Robson.
RGB port at the back has been enhanced to be compatible with Std Acorn BBC Scart cables.
Supplied with Resource CD, System Boot and Games Disc.
Asking £70 plus shipping, via Paypal gift or buyer pays fees.
