Sold TB486 486 PC/104 Module
danhans115
Rating - 94.7%
18   1   0
Leeds
Too many little projects and little time :).. I was going to build this into a small box and wire either a small 16bit soundcard or a covox to it but just never got round to it.
Its a AMD 486 - clockable from 66-133MHz, has onboard IDE, 2 x Serial, 1 x RS-422, 1x IRDA, 1x LPT, 1 x 44pin IDE, floppy and LCD interfaces as well as LCD. It also has 10mbit ethernet too but you would need to make your own adapter for it using a transformer (very easy). It has 2mb flash onboard with DOS installed and only requires +5vdc to get it up and running. a 16Mb memory module is also supplied with it
It comes with some adapters for the PS/2 keyboard and VGA and a laptop HDD or CF can easily be attached to the IDE port.
Only thing wrong with it is some of the PC104 expansion port pins on the underside have been snipped off. Not really a problem as such as yopu can just plug a PC/104 device on top if you have any.
Could be great as a small fileserver for a retro machine or something?
It comes as pictured, with the cables and I will email the buyer the manual in PDF format for the pinouts.
Looking for £6 + P&P
danhans115
Rating - 94.7%
18   1   0
Leeds
Payment recieved.(y)
Many thanks. I will get the module posted for you on monday and confirm despatch by PM.
Many thanks
Dan
mfilos
Extr3m3ly l33t
Glyfada/Athens
Item arrived today and feedback already left from my behalf. Thanks a lot :)
danhans115
Rating - 94.7%
18   1   0
Leeds
Glad it arrived safely :)
Here is the manual for the board itself in PDF.
And when you get an idea of what you are using it for, would love to see it.
All the best
Dan
  • TB486TRM.pdf
