testing the a4000 D stupid question
jvdbossc
HypnusBE
Belgium
Antwerp (province)
I am installing the DENEB USB, the manual states do not put it in the zorro slot the wrong way, but you can, what is the good way? solder down to the motherboard and components to the sky?
sorry poor amiga owner before..
Templar
Hellas
Cydonia
I had a Deneb card before, and I don't remember that you could insert it in the wrong way. Insert it as other normal cards.
jvdbossc
HypnusBE
Belgium
Antwerp (province)
txs,
txs,
I have no normal cards..
---------- Post added at 16:33 ---------- Previous post was at 16:33 ----------
the card can be down and up.. it is not like pci or isa...
keropi
Ioannina
1 picture = 1.000 words :)
jvdbossc
HypnusBE
Belgium
Antwerp (province)
it did help
it did help
yes it is installed, have another question know, but fits in new top.
this can be closed.
Non-commercial threads don't need to be closed, mate.(y)
jvdbossc
HypnusBE
Belgium
Antwerp (province)
clockport
clockport
think i found out the clockport orientation question myself, found some chematics online, stating the first pins have + 5 volts so used a multimeter.. Nothing burns, but not tested the catweasel. Post images today.. The leftover is 4.8 volts :dry: And it confirims to the 20 label..
jvdbossc
HypnusBE
Belgium
Antwerp (province)
ok the promised pictures
It is still not the way I wan't it, but well early stage of config: (yes I noticed that I should glue the catweasel less drunk :):) (i glued it in without looking at it from the back)(n)
I will paint the case, it looks yellow..No probs with that part I am better in painting than putting parts in
I installed the 68040 card, had the scandoubler in, the usb, the catweasel..
Not finished, I am better in dreaming then in realising :bowdown:
After formatting the cf in the real amiga, i decided to use winuae, wondering if anybody else thinks it is slow, compared to the real thing
jvdbossc
HypnusBE
Belgium
Antwerp (province)
ok
ok
might be the thing to do - will pm a chemist about Hydrogen Peroxide for the translation in Dutch and to check I can get it.:coffee:
arnljot
Dad, gamer, nerd, amigian
Oslo
Oslo
Just go to your local pharmacy. It's a scientific name they understand. In norwegian it's Hydrogen peroksid. So in duch I guess it's hyjdrogën paroksjidj.... :p
jvdbossc
HypnusBE
Belgium
Antwerp (province)
can do that
can do that
I alway's check when mixing such products with someone. It can save your life..
