The best commodore monitor for a1200/a4000?
kronuz
Norway
Oslo
Hi!
I´m looking for a monitor to use with my a4000 and a1200. It must be a commodore monitor.
I plan on using the monitor without graphics card, but would be nice to run 1024x768 with picasso iv later on.
Can anyone guide me to a good option.
The only experience I have with commodore monitors, is the 1084, that cannot run interlace without flicker.
Thank you!
jack-3d
kLik me
Czech Republic
Brno
Not sure if Commodore ever made such monitor. You probably mean multisynch monitor capacle 15 and also 31 kHz. Microvitec made such monitors and they are called M1438, M1538, M1738 and M1764. Sometimes these monitors has Amiga label instead of Microvitec (I have M1538 with Amiga label and it is excellent monitor). If you check BBOAH you can see many other monitors which the same apabilities. I personally know Nec Multisynch 3D is a nice monitor and at home I have Nokia 417TV which is one of the few 17" native PAL monitors ;o)
kronuz
Norway
Oslo
ColourWheel64
none
none
There are a handfull of 1024x768 capable commodore branded monitors, that were sold with the IBM compatible commodore PC´s
I was gonna suggest one of these. Hopefully, this'll sort you out. Using an indivision the results are noticeably jerkier. My hope is that a Picasso has a better output.​
BLTCON0
Math inside
Hellas (Greece)
Chania, Crete
But the latest commodore monitors, like the 1084ST, runs 640*512 without flicker straight from the Amiga...right?
No, the monitor must support 31 KHz horizontal sync. The Amiga may be able to promote the videomode, but also requires a capable monitor to match. I don't believe the 1084ST is any different in that area from other 1084's etc - it still only supports 15 Khz.
You'll need what jack-3d says.
kronuz
Norway
Oslo
ahaa, of course!
The 1960 is what I want :D
Thanks guys. Have a great weekend!! :pint:
