Thylacine USB - any other users here?
  • Replies Replies 3
  • Views Views 1251
fitzsteve
Retired Slacker
Assistant
Sevenoaks
I have a Thylachine, one of the last few from the original seller in Australia.
It seems to work fine with Poseidon 4.4 however the device driver seems to time out when copying files from USB stick for example.
Anyone else have experience with this hardware? It would be nice to hear about how you get on with it.
I've only tested it with A4000's, never in a ZorroII machine which is probably where it should be installed really!
Cheers,
Steve.
Yes, I actually worked in with Chris Hodges to try and get a driver that would work without this problem... He did release a new driver (available on his homepage - but probably no longer) but it didn't really solve the issues ultimately... I was forever restarting it or similair... as you are doing, I doubt I could find the driver but I will have a look when I get home from work and let you know
And yes, I used it under 3.9 on an A4000
Many thanks, I'll try that a little later :thumbsup:
