for sale is an Amiga 3000 desktop put in a pc tower case. The motherboard is a revision 9 with a 68030 at 25 Mhz. It comes with 4 MB of static column fast ram (so burst mode can be enable), 2 MB of chip ram, os 3.1 roms, cdrom drive, a 340 MB scsi hard drive and a 200w power supply. The battery has been replaced before any leakage, so the motherboard is clean as you can see on the pictures below. This amiga was sleeping since ten years until now. It has been fully tested and works great:
The mouse port, the joystick port, the keyboard port, the rca audio port, the video port and the external floppy port were tested with their respective device; the flicker fixer with a vga monitor; the parallel port with an hp laserjet printer; the serial port with a serial to usb adapter connected to a linux box; The external scsi port with an external scsi zip drive; and the zorro bus with a GVP spectrum graphic card.
The fast cpu slot was tested with an A3640 expansion board and the 3000 worked fine with it (no scsi problem for example).
The power supply is strong enough to put whatever expansion board you want.
In this configuration, you can put any cpu expansion made for 3000 or 4000: there is no overheat or space problem for that.
You need to use an A4000 keyboard, due to the ps/2 connector at the back of the tower.
The INT2 signal is connected to the fast cpu slot, so no problem at all to use the scsi controller of a cyberstorm.
The price is 400 euros + paypal fees + shipping costs.
More big size images:
Image01 - Image02 - Image03 - Image04 - Image05
Image06 - Image07 - Image08 - Image09 - Image10
Image11 - Image12 - Image13 - Image14
UPDATE OF 11/10/13 : NEW PRICE
300 euros for A3000 only
350 euros with Amiga Keyboard and Amiga mouse, or the Lyra and EZMouse interfaces to use PS/2 keyboards and mice.
