Hi all,
Following a rethink of my home network requirements, I no longer require either of these items.
First item is a TP Link range extner. These are useful if you have a weak wireless signal in parts of your home/ business as this can considerably increase the range of the network. I bought this as a new open box unit and used it for perhaps 10 minutes before replacing my router. My new router has a considerably better wireless signal than my old one, hence this is no longer needed.
A bit of the blurb from TP-Link:
'TP-LINK’s TL-WA830RE 300Mbps Wireless N Range Extender is designed to extend the coverage and improve the signal strength of an existing wireless network to eliminate “dead zones”. Combined with leading wireless N technologies, superior security and wider compatibility, TL-WA830RE makes it a secure high speed solution that can help you keep an existing wireless network unchanged and vastly improve the network’s coverage, giving you the freedom to enjoy Internet anywhere uninterruptedly in large areas such as homes, hotels or small offices without worrying about coverage limits.
TL-WA830RE is designed to select “Range Extender” as the default wireless mode, working as a “relay station” to repeat the wireless signal flawlessly to longer distance where is previously outside the coverage of the existing wireless network. Due to leading Wireless N technologies, it can overcome obstacles and enhance overall network signal quality, then providing the same reliable network connecting as wired network. Better still, TL-WA830RE can also work in the conventional AP mode, accessing the Internet via ADSL/Cable modem and linking the wireless and wired network together.
Next item is an HP wireless G USB printer server. This allows a USB printer to be shared across a wirless network even if it is not wireless itself. Unfortunately this was not compatible with my printer (HP 970cxi) and my new router has a USB print server built in, so again surplus to requirements!
Specs: http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/18972-18972-236253-34210-396578-3662201.html?dnr=1
The 10 pence piece in the pictures is to judge scale and is not included!
Price is £14 posted to UK. Overseas please ask.
Payment is to be made by PayPal or cash on collection. Payment by PayPal gift only, unless you wish to upgrade to signed for postage (£1), in which case you may choose to pay the paypal fees. Just add 3.9% + 20p to the total due to cover the fees.
Any questions, please feel free to ask!
- 300Mbps wireless speed ideal for smooth HD video, music streaming and online gaming
- Two MIMO antennas greatly extend your existing wireless coverage to eliminate “dead zones”
- Easily extend wireless coverage only in a few seconds at a push of Range Extender button
- Working seamlessly with all 802.11b/g/n devices
- Bundled Easy Setup Assistant helps set up the connection step by step in minutes'
