As Steve said, you probably already have a modern (>4GB capable) IDE driver on your 32GB card, but most of these drivers are amiga model specific, so you need to swap it out with the A4000 version.
It’s also possible that your card has idefix running, and not a regular scsi.device. S:Startup-sequence will tell you. (or ‘version scsi.device’) Idefix is not model specific.
The IDE driver is called scsi.device. The original version is in your kickstart chip, and the new version is possibly loaded in s:startup-sequence with the loadmodule command.
If it is, replace the scsi.device file that loadmodule loads with the 4000 equivalent.
If it’s a classicwb setup it has the 4000 file stored somewhere already. A folder named large drive support or similar.
It’s not a fool proof idea to just test the card in the 4000. It will probably just fail during boot. (loadmodule will fail). But if you boot without startup-sequence or somehow end up with the card running without large drive support, the card will be trashed as soon as you write anything to it…
I really should update that FAQ for OS3.2 etc. At least it’s still mostly relevant for you guys on 3.1
