Turrican 3 C64 / SD2iEC loading - Help!
dougal
Malta
My SD2IEC arrived today and works great but I can't load Turrican III as I dont know which file to load.
Usually on real disk i'd just type load "*",8,1 and thats it ... not even RUN
On SD2IEC i get inside the turrican 3 disk 1 d64 image in cbm browser but there are loads of files... no idea. stuck
dougal
Malta
Someone got as an M2i version but I can't find any info about that
dougal
Malta
Found an M2i version and it worked :)
Won't work with fast load but works fine normal load
Paradroid90
C64 Junkie
Chatham Kent
Just a little tip regarding the SD2IEC, if you are looking for certain software that back in the day that use multiple disks, try to hunt down a d81 images as these work great on the SD2IEC also :)
dougal
Malta
Thanks! Are d81 images both(or more) disks in 1 file ?
SaviorX
VCCUG
Canada
Calgary, Alberta
they are just images of 1581 800k disks, if a 'multidisk' game is on a 1581 it is likely a 'cracked' version
