UAE Hardfile problem
arnljot
Dad, gamer, nerd, amigian
Oslo
Oslo
Duplicate post vs EAB
Setup:
UAE 2.0.1
Rom settings: A4000 extras, using an A4000 KS Rom file
Created 1GB hardfile, attatched to IDE0 (only define size to 1024MB and save it as OS30.hdf, then select it to use it in the file requester)
Problem:
I set it up in WB3.0 with HD toolbox, define, partition, save and reboot.
Upon reboot the partition is gone, and opening HD Toolbox states that the drive has changed, and the cycle starts all over again. I have to define, partion save and reboot.
What am I doing wrong here?
Chipset settings
ROM settings:
Harddrive settings:
Hardfile Settings:
RedDaemonFox
Amiga's enemy is my enemy!
United States of Hell
Melbourne, FL 32901
A few issues (some are opinions)
UAE 2.0.1. It seems this version breaks this function, I only use real drives with this version (my CF drive) with the bare minimums for speed. Report it to the dev team. Try using 2.0.0.
and a question
What are you using this for? Games? File transfer? I use, bare minimum, 3.1, never anything else unless absolutely necessary
arnljot
Oslo
Oslo
LOL
Actually, I wanted to set up a Wb 3.0 setup to make screenshots for your file copy example. So in some ways it was for you ;-)
BTW, re your signature... ;-)
RedDaemonFox
Melbourne, FL 32901
Huh? i don't understand about my sig?? Anyways, that was all cleared up. I'll have to learn Amidos tho. here is my setup on WinUAE for transferring files to my CF.
I use a targus CF/SD reader USB. I add the HD to IDE0, appears as multiflash reader. I use an A1200 3.1 rom, 3.1 WB floppy and set Turbo for floppy speed. I use an 040 for CPU so it boots fast, chipset is AGA w/ 1200 extras. 8 chip ram, 16 fast. I have 1-2 extra floppy drives and I add what ever directories/LHAs I want transferred in the HDD setup. I'd do screenshots, but I'm on my powerbook, and e-uae is different, doesn't support USB drives, etc. Maybe later
arnljot
Oslo
Oslo
Re hardfile problem:
Toni sorted me out over at EAB, I was using the software the wrong way. I didn't know that to use HD Toolbox I have to enable RDB Mode.
Re your signature:
Is it really complaints you have? They read more like demands to me ;-)
@Mods:
Please mark this thread "SOLVED".
