** PRICE REDUCED 3/10/2013 - NOW ONLY £135 PLUS DELIVERY **
** ONLY AVAILABLE FOR TODAY BEFORE THIS GOES ON EBAY TOMORROW **
** OPENED TO OVERSEAS BUYERS TOO **
I have the following for sale...
UNI-T UTG9020A 20Mhz DDS Function Generator
Specs as follows:
Waveforms - Sine, Square, Triangle, Ramp up, Ramp down, Expontential Rise, Exponential Fall Sine
Range - 0.1Hz to 20MHz
Accuracy - 0.01Hz(<=3.05KHz), 1Hz(>3.05KHz)
Resolution - 0.01Hz or 8 digit
Stability - <1ppm/C
Harmonic Distortion - <-55dBc to 20KHz <-50dBc to 1MHz <-40dBc to 10MHz <-30dBc to 20MHz
Square Range - 0.1Hz to 5MHz
Rise/Fall Time - <20ns
Duty Cycle - 20% to 80%
Triangle, Ramp, sin(x)/x Range - 0.1Hz to 1MHz
Linearity - <0.2% to 30KHz
Amplitude Range - 0.5mVpp to 10Vpp (50ohm), 1mVpp to 20Vpp (HiZ)
Accuracy - +/-5%
Resolution - 0.1mV
Output Impedance - 50ohm
Attenuator - 20dB + 40dB
DC Offset -10V to +10V
Ext Amplitude Mod
Input Impedance - 1Kohm
Modulation Depth Controlled by amplitude of ext sig, 100% (5Vpp)
Frequency Counter Amplitude Range - 0.1Vpp to 5Vpp
Input Impedance - 10Kohm
It is fully boxed with all manuals, bmc to crocodile clips lead and power lead.
Only one point to note and that is that I removed the handle as I could not get it on my shelf and the handle was subsequently binned.
Looking for (was £165) JUST £135 plus delivery at cost.
I will combine shipping on the other stuff I have for sale in other threads (Function Generator, Power Supply, Bench Multimeter, loads of other electronics gear etc).
Specs as follows:
Stability - <1ppm/C
Accuracy - +/-5%
Resolution - 0.1mV
Ext Amplitude Mod
