Any USB Card reader will be fine (check eBay, etc) as long as they have the standard 9 pin connector that most PC Motherboards have (USB2) but note if you use the internal header you can't use the rear USB ports on the X-Surf anymore.
thats mean , if I will buy RapidRoad usb for x-surf 100 and connect this device to front 3.5 card reader then , rear x-surf100 port will be not active ?
Yep, that's correct. You would need to use some kind of USB hub to get more ports, it only has two ports either by the internal header or the activation of the two rear ports on the X-Surf, not both. I checked this with Jens since I use an internal reader in my A4000 from when I had a Deneb installed.
I'm thinking maybe better (for my needs) to get another Deneb as I'm sure the release of the Rapid will bring down the price of them Deneb!
