Sold Various items for A4000 and A1200
turboknekten
Sweden
Lidköping
Hi everyone,
My A4000 and A1200 are sold.
Here are some left over items.
Firebird A4000: 40EUR (sold to witchdoctor75)
Sold as untested/Non working.
Before I sold my A4000 I swapped the original daughtercard with this Firebird card. I have only tested a Compserv scandoubler card in lower slot.
I got picture to monitor. A colleague at work did the soldering of the upper Altera chip and the programming of the two Altera-chip and XC9572XL chip. One extra Altera chip is coming with the card.
So no proper testing.
Freeway Triton USB: 40EUR (sold to hese)
Before I sold my A4000 I put the card in upper slot of original daughter-card to see if computer recognize the card. Sorry for the bad quality of the screen pictures. I took those when I had hires interlaced as resolution. Computer was sold before I checked pictures. This was the only test I did.
Various adapters + clock kit: 30EUR (sold to Amiga_walker)
-Two CF-card adapters. For a while I was using the big adapter in my A4000. The small green one with cable in picture has never been tested.
-Two bigger SATA to IDE adapters. Not been tested. I bought three on Amazon. I only used one of the adapters in my A4000 together with a SSD SATA drive.
-One small SATA to IDE adapter + cable. Dont remember if this adapter was tested or not. So sold as untested.
-A4000 clock repair kit. Bought on Ebay.
Picowyfy for A1200: 30EUR (sold to hese)
This device I was using in my A1200 (that had a Blizzard 1230 card with 16Mb of memory) before computer was sold.
Payment method: Paypal f&f
Shipping:
EU: from 10EUR to 25EUR depending on item
UK: from 10EUR to 25EUR depending on item
US: from 10EUR to 25EUR depending on item
rest of the world: ask me
2025-05-21 Update:
PM sent to hese about shipping cost. Payment received.
PM with payment info sent to witchdoctor75. Payment received. Will post package tomorrow.
2025-05-22 Update:
Package sent to both hese and witchdoctor75. PM with tracking number sent to both.
2025-05-23 Update:
Payment received from Amiga_Walker. Package sent. PM with tracking number sent.
Payment sent for the Freeway Triton USB and PicoWyfy.
@hese
Now that you will get one PicoWyfy I have a suggestion for you
You will be able to test your PicoWyfy with the new Firebird v1.1
The clockport is on the front (ok) but when you attach the PicoWyfy on a A3000/A4000 you need to remove the metal case out because the PicoWyfy vertical placement does not allow the metal case to be placed
I was thinking on something for your consideration
The best placement for the PicoWyfy would be on the back of the Firebird board but we cannot simply desolder the clockport connector and place it on the back because the pinout would not match
My suggestion would be to create a tiny PCB board that would connect to the back of the Firebird board (clockport pins), make the necessary track connections to place the clockport connector on the back of the Firebird board
This way we could connect the PicoWyfy parallel with the Firebird board but now facing down (not touching the motherboard)
This would allow the A3000/A4000 metal case to be closed
It’s only a suggestion 😀
