Closed VIC-20 Final Expansion Alpha 512kb RAM + 512KB Flash
  • Thread starter Thread starter pazuzu72
  • Replies Replies 5
  • Views Views 1801
pazuzu72
Italia
Brindisi
Final Expansion Alpha (Derived from Final Expansion 3) *
This version comes without sd2iec (and RTC). This allows it to be cheaper since the SD2IEC is very common and therefore probably already owned by the user (otherwise you can buy any to use also on other commodore computers).
Memory expansion for Vic20 (without switch, all by internal menu) 3Kb-8Kb-16Kb-24Kb-32Kb-35kb.
512KB Flash ROM for loading many Vic-20 cartridge images.
Internal menu for memory configuration.
Onboard RAM (512KB total) can also be used as a large RamDrive *** or task switcher *** , such as having multiple switchable Vic20 sessions.
Cartloader through which you can conveniently start programs, which are stored in the memory. There are 480 KB (of 512 KB) available in flash. You can transfer your favorite programs to flash memory **.
Wedge: This little tool expands the VIC-20 instruction set and implements SJLOAD / SJSAVE (Jiffy compatible load and save).
Suitable for both VIC-20 PAL and NTSC
Latest firmware installed (upgradeable).
The board comes without a shell but the PCB is perfectly compatible with the standard Vic-20 shells, just need to drill 2 holes for the buttons.
Alternatively, I can provide the STL files for 3d printing of the model made specifically for this cartridge.
On youtube there are various videos showing how it works
https://www.youtube.com/watch?v=0v0uNSn_T64
* The project from which this version is derived is open-source. Does not include SD2IEC and RealTime Clock. The functionalities and any changes are the same as the original project, as well as firmware updates etc.
https://oe7twj.at/images/7/7b/FE3_User_Manual.pdf
** A SD2IEC is recommended , or at least a PI1541 or a real drive is required for loading the ROMs.
*** Need external utility downloadable for free!
PRICE is 49 EUR (+ paypal fees 4%)
Shipping cost:
Italy 3 EUR POSTA1
Italy SDA Courier 7 EUR
Europe 10,80 EUR
Europe 5 EUR (international priority mail)
photo_01.jpg photo_02.jpg photo_03.jpg photo_04.jpg photo_05.jpg photo_06.jpg photo_07.jpg
