Sold Vintage Retro Socket 2 Pc COMPAQ DEKSPRO XE 466
Dezsoapolip
Rating - 88.9%
8   1   0
Hungary
Szombathely
Hy.
I want to sell this Vintage Retro Socket 2 Pc COMPAQ DEKSPRO XE 466.No ps unit it was broken.I have no 14 pin vga can test integrate videocard,i try with 16 bit vga with risercard but something wrong.Mb drop green light cpu get heat.Have some question just pm to me.I want ask (39) 30 € + post pp friends or gift option.I selling multiple sites!
Thanks for check,have nice day. :)
Compaq Deskpro XE 466 Specifications
The specs for Deskpro XE 466 comes in these configurations with a retail price tag. The configuration Compaq provides comes with a 66MHz Intel i486DX2 n/a n/a ISA DOS,1 socket 1 MB (non-removable) 2 MB.
This Compaq Computer can take up to 32 MB ram, with a fixed amount of 4 MB (non-removable) + 0 or 4 removable = 4 or 8MB installed Although it is physically possible to install more memory the system will only recognize 32MB maximum..
This full-featured mainstream Computer enhances the previous generation Compaq models with the chipsets and new levels of customization. Get the best experience on your Compaq Deskpro XE 466 Computer with improved performance, make it easy to create a home network and share all of your favorite items.
The specs of Computer shows full configuration information. The Deskpro XE 466 is designed for users who require maximum performance in a mainstream Computer. Even with its form factor design, the Deskpro XE 466 doesn't skimp on performance offering the ideal blend of power and efficiency. The Deskpro XE 466 is sure to leave a lasting impression with its easy to use and slim design. Located on the side of the unit, the modular bay's innovative latch is designed for easy insertion and removal of the various module options.
The Deskpro XE 466 Computer only supports 66MHz Intel i486DX2. The Deskpro XE 466 features two on-board data caches for transferring information to and from the processor. These caches are known as the L1 and L2 caches. The Deskpro XE 466 L1 cache is 64 kilobytes in size, while its L2 cache is rated at either one or two megabytes.
When you have a clear idea of which Computer best suits your needs, check for its specifications. As the Deskpro XE 466 is supported by Compaq, check if the Computer has full support and warranties by its manufacturer, like Deskpro XE 466 specs you will have lots of options from the Computer manufacturer to choose from, like the Computer processor, Computer RAM, its graphics capacity, Computer display options and specs, and other features that the Computer provides. You should have an idea on what specs you want from your Computer and what specs you do not want on your Computer, deciding on Computer specs may be difficult task to do but like the Deskpro XE 466 specs have, it's essential to selecting a Computer you need at a price tag that it deserves and that you can afford.
Here is a sample Deskpro XE 466 Computer specification if you want an initial guide to buy a Computer. More or else, these are the specs factors often that you should take into consideration before you purchase a particular type of Computer. To help you navigate around the hassles of buying a Computer, we have the standard specifications for most home and small business users.
Similar threads
