Voodoo and WHDLoad causing a black screen
  • Thread starter Thread starter lurch
  • Replies Replies 16
  • Views Views 4664
lurch
new zealand
Auckland
So after googling my eye balls out I've decided I must admit defeat and see if there's some resident guru's that can help :-)
I've even registered with Elbox, but haven't heard back from them. Not sure what's up with that.
But anyway, I have the legendary issue of a black screen when switching from RTG to native :-(
The only two games that work are Silkworm and SWIV.
My config:
Amiga 1200, Apollo 060 @ 80MHz, Subway USB, Mediator TX, Indivision AGA Mk2, Voodoo 3, SB128, Realtek NIC, Radeon 9200, Fast ATA, kick 3.1 / 3.9.
Prolly other items I've forgotten.
If I disable the Voodoo card all games run great, as soon as the Voodoo card is enabled wham black screen again.
I've tried:
Voodooinit=No - Man this really slows the Amiga down :-/
FakeNativeModes=No
I've followed the guide here: http://warpclassic68k.blogspot.fr/p/ma-config.html
Even installed the same library versions.
I went back to WHDLoad 6.9, then 7.1, even 7.2. I've registered WHDLoad BTW.
Ive tried picasso96 v2.0, b, and c.
I've tried reinstalling AmigaOS3.9.
Reading on the WHDLoad page the Voodooint issue was resolved.
As I've said if I disable the Voodoo all is well, I can even leave the Radeon in the machine and use the extra fast RAM as long as the Voodoo is disabled.
My final test will be to use the Radeon on it's own as the main RTG card, but don't really want to loose the Warp3d stuff.
Anyway will post more what I find out, but open to suggestions :-)
---------- Post added at 07:17 ---------- Previous post was at 07:15 ----------
Knew I forgot something I also use the Roadshow TCP stack. Yes both the TCP stack and Subway are unloaded before WHDLoad start as I'm using the startup/cleanup scripts.
Which work fine with the Voodoo disabled.
I've also tried the NOAUTOVEC option :-(
i have a similar setup hear and have no problems whatsoever.
i'll try some games that dont work for you if you mention them,but i suspect its something in your software setup causing problems and not hardware.
lha your DH:0 and upload it so he can try out your installation to rule out the hardware :)
Remeber to remove all the pr0n before you do it :p
i dont have any file sharing software installed on my pc anymore:(
Post medconfig report, maybe there's something that's causing the issue.
Only games that work are silkworm and SWIV :-) It's not a hardware issue, something software is causing the problem.
I've just reloaded from scratch Picasso96 2.1b and the Mediator.
Anyway report below :
*** Envarc: variable settings: ***
MMU = Yes, previous setting: Yes
NoCache = Not Set, previous setting: Not Set
Emulation = Not Set, previous setting: Not Set
Buster = Not Set, previous setting: Not Set
RadeonMem = 32, previous setting: 32
VoodooMem = 12, previous setting: 12
VoodooInt = Yes, previous setting: Yes
VirgeMem = Not Set, previous setting: Not Set
VirgeInt = Not Set, previous setting: Not Set
Warp3D = Yes, previous setting: Yes
Gfxaddr = Not Set, previous setting: Not Set
Force = Not Set, previous setting: Not Set
Terminator = Not Set, previous setting: Not Set
Memsize = Not Set, previous setting: Not Set
FastEthernet = 0, previous setting: 0
tv.prefs file name = Not Set, previous setting: Not Set
Tuner = Not Set, previous setting: Not Set
Background = Not Set, previous setting: Not Set
*** Mediator System Files versions: ***
pci.library - ver.9.7 (11632 bytes)
MediatorNET.device - ver.2.10 (6176 bytes)
Radeon.card - ver.2.12 (15936 bytes)
Voodoo.card - ver.4.30 (14768 bytes)
Virge.card - ver.1.13 (12064 bytes)
Vendors.txt - ver. info N/A (219437 bytes)
MedConfig - ver.1.9 (119295 bytes)
*** Mediator Multimedia CD Files versions: ***
FastEthernet.device - ver.1.21 (7024 bytes)
mixer.library - ver.1.11 (4016 bytes)
fm801.audio - ver.4.14 (4156 bytes)
FM801 - ver. info N/A (1180 bytes)
sb128.audio - ver.4.20 (6336 bytes)
SB128 - ver. info N/A (2032 bytes)
SBMixer - ver.1.4 (2004 bytes)
tv.library - ver.4.13 (10304 bytes)
TV - ver.1.4 (1956 bytes)
tv.vhi - file N/A
*** Spider Files versions: ***
poseidon.library - ver.4.4 (116112 bytes)
spider.device - ver.3.20 (18560 bytes)
DriveSpeed - ver.1.2 (1960 bytes)
*** Warp 3D files versions: ***
Warp3D.library - ver.4.2 (215888 bytes)
Warp3DPPC.library - file N/A
*** Warp 3D for A3/4000 files versions: ***
W3D_Picasso96.library - ver.4.2 (39216 bytes)
W3D_Picasso96_PPC.library - file N/A
W3D_AvengerBE.library - ver.4.2 (295716 bytes)
W3D_AvengerBE_PPC.library - file N/A
W3D_AvengerLE.library - ver.4.2 (282312 bytes)
W3D_AvengerLE_PPC.library - file N/A
*** MMU Warp 3D for A1200 files versions: ***
W3D_Picasso96MU.library - ver.4.2 (7936 bytes)
W3D_AvengerBEMU.library - ver.4.2 (279268 bytes)
W3D_AvengerLEMU.library - ver.4.2 (279296 bytes)
*** NO_MMU Warp 3D for A1200 files versions: ***
W3D_Picasso96M.library - ver.4.2 (12780 bytes)
W3D_Picasso96M_PPC.library - file N/A
W3D_AvengerBEM.library - ver.4.2 (535304 bytes)
W3D_AvengerBEM_PPC.library - file N/A
W3D_AvengerLEM.library - ver.4.2 (535388 bytes)
W3D_AvengerLEM_PPC.library - file N/A
*** Other files versions: ***
AmigaOS ROM Update - file N/A
rtg.library - ver.40.3992 (217988 bytes)
emulation.library - ver.40.389 (39652 bytes)
Picasso96API.library - ver.2.300 (24520 bytes)
ahi.device - ver.6.6 (83908 bytes)
68040.library - ver.60.1 (392 bytes)
68060.library - ver.43.1 (64820 bytes)
warp.library - file N/A
ppc.library - file N/A
scsi.device - ver.50.0 (-1 bytes)
FastATA.driver - file N/A
ATA3.driver - ver.7.1 (18960 bytes)
4xEIDE.driver - file N/A
model - , gfx - , zorro - , pcmcia - ,
serial - , ppc - , mmu030 - , mmulib - ,
nocache - , emulation - , warp3d - , pci - .
startup-sequence:
; $VER: Startup-Sequence_AmiKit OS3.9 BB2
; Startup-Sequence for AmigaOS 3.9 + AmiKit (by Jan Zahurancik ©2005-2008)
; Modified to work with real Amiga by Retrofan
C:ATA3.driver RESIDENT QUIET
C:stack 8192
Run >NIL: C:DRAP
if WARN
Run >NIL: C:RemAPollo QUIET
EndIf
C:Safe RENRAM OWNOUT MOUNTSIZE=6684 ;Checks for viruses
C:morelibspace
SetPatch SKIPROMUPDATES "scsi.device" QUIET
C:mcpramlibpatch
Run >NIL: C:wbm
Assign >NIL: Amikit: System:
;BootScreen by Joseph Luk
;BootScreen
;run >NIL: C:Play16 Priority 1 ;SYS:Prefs/Presets/Sounds/Opening_Theme_A.aiff
;C:Wait 5
;C:CyReq
C:BlazeWCP
C:StackAttack 32768 ;adds stack size to selected value
C:PatchControl ;part of MCP
C:TagLiFE ;patches the utility.lirary
C:Version >NIL:
C:AddBuffers >NIL: DF0: 15
FailAt 21
C:MakeDir RAM:T RAM:Clipboards RAM:ENV RAM:ENV/Sys RAM:T/VC_TEMP
C:Copy >NIL: ENVARC: RAM:ENV ALL NOREQ
Resident >NIL: C:Assign PURE
Resident >NIL: C:Execute PURE
Assign >NIL: ENV: RAM:ENV
Assign >NIL: T: RAM:T
Assign >NIL: CLIPS: RAM:Clipboards
Assign >NIL: REXX: S:
Assign >NIL: PRINTERS: DEVS:Printers
Assign >NIL: KEYMAPS: DEVS:Keymaps
Assign >NIL: LOCALE: SYS:Locale
Assign >NIL: LIBS: SYS:Classes ADD
Assign >NIL: HELP: LOCALE:Help DEFER
Assign >NIL: L: SYS:Utilities/Expansion/SmartFileSystem/L ADD
Assign >NIL: A-Programs: SYS:Programs
Assign >NIL: A-Temp: SYS:Temp
C:FBlit
C:FText
IF $bbfix EQ "0" ;adjusts AmiKit if both BoingBags for OS3.9 were installed
version >NIL: Shell VERSION 45
IF NOT WARN
IF EXISTS SYS:WBStartup/AmiDock
IF EXISTS SYS:WBStartup/Disabled/AmiDock
Delete >NIL: SYS:WBStartup/Disabled/AmiDock FORCE QUIET
ENDIF
Rename >NIL: SYS:WBStartup/AmiDock TO SYS:WBStartup/Disabled/AmiDock QUIET
ENDIF
IF EXISTS SYS:WBStartup/ASyncWB
IF EXISTS SYS:WBStartup/Disabled/ASyncWB
Delete >NIL: SYS:WBStartup/Disabled/ASyncWB FORCE QUIET
ENDIF
Rename >NIL: SYS:WBStartup/ASyncWB TO SYS:WBStartup/Disabled/ASyncWB QUIET
Delete >NIL: SYS:WBStartup/ASyncWB.info
ENDIF
IF EXISTS SYS:WBStartup/BenchTrash
IF EXISTS SYS:WBStartup/Disabled/BenchTrash
Delete >NIL: SYS:WBStartup/Disabled/BenchTrash FORCE QUIET
ENDIF
Rename >NIL: SYS:WBStartup/BenchTrash TO SYS:WBStartup/Disabled/BenchTrash QUIET
ENDIF
IF EXISTS SYS:WBStartup/DefIcons
IF EXISTS SYS:WBStartup/Disabled/DefIcons
Delete >NIL: SYS:WBStartup/Disabled/DefIcons FORCE QUIET
ENDIF
Rename >NIL: SYS:WBStartup/DefIcons TO SYS:WBStartup/Disabled/DefIcons QUIET
ENDIF
Delete >NIL: SYS:Utilities/Amplifier#? FORCE ALL QUIET
Copy >NIL: SYS:Prefs/Presets/AmiKit/Install/System TO SYS: CLONE ALL QUIET
SetENV bbfix 1
Copy >NIL: ENV:bbfix TO ENVARC: CLONE QUIET
EndIF
EndIF
C:Version >NIL: SYS:Libs/xadmaster.library 12 1 FILE ;installs latest XAD if BoingBag1 for OS3.9 was installed only
IF WARN
EndIF
C:Version >NIL: SYS:Classes/DataTypes/ilbm.datatype 44 26 FILE ;adjusts AmiKit if BoingBag35-2 was installed
IF WARN
Copy >NIL: SYS:Prefs/Presets/AmiKit/Install/System/Classes/DataTypes/ilbm.datatype TO SYS:Classes/Datatypes/ CLONE QUIET
EndIF
C:CPU60 B >NIL:
Run >NIL: CopyMem060
IF NOT EXISTS SYS:Fonts
Assign FONTS:
EndIF
BindDrivers ;useless on UAE
C:Mount >NIL: DEVS:DOSDrivers/~(#?.info)
;C:LoadMonDrvs
;IF EXISTS DEVS:Monitors
; IF EXISTS DEVS:Monitors/VGAOnly
; DEVS:Monitors/VGAOnly
; EndIF
C:List >NIL: DEVS:Monitors/~(#?.info|VGAOnly) TO T:M LFORMAT "DEVS:Monitors/%s"
Execute T:M
C:Delete >NIL: T:M
EndIF
;C:P96-EmulationUpdate ;fakes the version info of emulated CGX libraries under Picasso96
;C:P96Refresh >NIL: 100 ;set this value (100 by default) according to your monitor refresh rate and WinUAE display settings
;C:P96Refresh
;SYS:Utilities/Expansion/ShowAmiga96/Bin/ShowAmiga96_Rev239C18 ;shows the picture during startup
SetEnv Language "english"
SetEnv Workbench $Workbench
SetEnv Kickstart $Kickstart
UnSet Workbench
UnSet Kickstart
C:AddDataTypes REFRESH QUIET
;Following two lines provide TrueType support. IMPORTANT: if you disable them you must enable C:WAIT line in front of C:IPREFS to avoid startup crashes!!!
;Assign >NIL: AfA_OS_Libs: SYS:Utilities/EXPANSION/AfA_OS/AfA_OS_Libs
;C:AfA_OS_Loader
;IF NOT EXISTS ENV:afa/replacevisualprefs ;enables the following lines only if similar featrues are disabled in AfA_OS
Run >NIL: SYS:Utilities/Expansion/TitleShadow/TitleShadow ;enables effects for window titlebar texts
Run >NIL: SYS:Utilities/Expansion/VisualPrefs/VisualPrefs ;enables the customization of Amiga GUI
Run >NIL: SYS:Utilities/Expansion/VisualPrefs/TRAP ALL ;enables the customization of Amiga ReAction GUI
;ENDIF
;C:Wait 3 ;prevents IPrefs from crashes. Increase the value if IPrefs still crashes.
C:IPrefs
;SYS:Utilities/Expansion/ShowAmiga96/Bin/ShowAmiga96_Login >NIL:
SYS:Utilities/Expansion/FullPalette/FPPrefs ;applies FullPalette settings
C:ConClip
;IF EXISTS C:CyberBugFix
; C:CyberBugFix
;EndIF
Path >NIL: RAM: C: SYS:Utilities SYS:Rexxc SYS:System S: SYS:Prefs SYS:WBStartup SYS:Tools SYS:Tools/Commodities SYS:Utilities/PicShow SYS:Utilities/EvenMore SYS:Utilities/MysticView SYS:Utilities/SimpleFind3 SYS:Utilities/Expansion/SmartFileSystem
IF NOT EXISTS ENV:afa/replacebirdie ;enables gfx patterns for windows borders (only if similar feature is disabled in AfA_OS)
C:Wait 3 ;prevents Birdie from not loading the background picture.
Run >NIL: SYS:Utilities/Expansion/Birdie/Birdie ? <Env:Birdie.prefs
ENDIF
SYS:System/REXXMast >NIL:
IF EXISTS S:User-Startup
Execute S:User-Startup
EndIF
IF EXISTS S:AmiKit-Startup
Execute S:AmiKit-Startup
EndIF
;following lines enable enchanced CLI/Shell functionality
IF EXISTS DEVS:KingCON-mountlist
Assign CON: DISMOUNT
Assign RAW: DISMOUNT
Mount CON: from DEVS:KingCON-mountlist
Mount RAW: from DEVS:KingCON-mountlist
ENDIF
Resident Execute REMOVE
Resident Assign REMOVE
C:Version >NIL: C:MakeLink 37 4 FILE
IF NOT WARN
C:Copy >NIL: ENVARC:SYS/def_RAM.info RAM:Disk.info CLONE QUIET
ELSE
C:MakeLink >NIL: RAM:Disk.info ENVARC:SYS/def_RAM.info SOFT
ENDIF
;Run >NIL: SYS:Utilities/Expansion/PowerIcons/PowerIcons >NIL: ;enables PNG icon support (Don't use it if AfA_OS_Loader is enabled!)
C:WBCtrl IMT=FAST MNL=100 ;tweaks Workbench
;Run >NIL: C:CPointer ;centers the mouse pointer on the screen (regardless of the screenmode used). Disable this entry if some of the other CPointer line is enabled.
;Run >NIL: C:CPointer XPOS=400 YPOS=368 MCLICK=50 ;for 800x600 screens, automatically clicks the Dopus "RUN" button
Run >NIL: C:CPointer XPOS=510 YPOS=455 MCLICK=50 ;for 1024x768 screens, automatically clicks the Dopus "RUN" button
;Run >NIL: C:CPointer XPOS=576 YPOS=500 MCLICK=50 ;for 1152x864 screens, automatically clicks the Dopus "RUN" button
;Run >NIL: C:CPointer XPOS=641 YPOS=579 MCLICK=50 ;for 1280x1024 screens, automatically clicks the Dopus "RUN" button
;Run >NIL: C:CPointer XPOS=797 YPOS=674 MCLICK=50 ;for 1600x1200 screens, automatically clicks the Dopus "RUN" button
;Run >NIL: C:PatchAsl ;enables MUI file requesters
;C:ChangeExp ;prevents from identifying your system as UAE
IF EXISTS S:AmiKit-StartOS ;starts Magellan II, Scalos or Workbench - depends on your MorpheuZ settings.
Execute S:AmiKit-StartOS
ELSE
C:LoadDB SIMPLEGELS
EndIF
C:MemTrailer SIZE=96 ;provides partial memory protection
EndCLI >NIL:
PciInfo report:
Pci Device 1:
VendorID: $121a
VendorName: 3dfx Interactive Inc
DeviceID: $5
DeviceName: Voodoo3 All Voodoo3 chips, 3000
ClassCode: $30000
RevisionID: $1
InterruptPin: 2
SubsystemVendorID: $121a
SubsystemID: $57
MemSpace0: $80000000 - $81ffffff
MemSpace1: $82000000 - $83ffffff
IOSpace2: $ed6000 - $ed60ff
RomSpace: $84000000 - $8400ffff
Pci Device 2:
VendorID: $1274
VendorName: Ensoniq
DeviceID: $5000
DeviceName: ES1373 AudioPCI
ClassCode: $40100
RevisionID: $1
InterruptPin: 3
SubsystemVendorID: $4942
SubsystemID: $4c4c
IOSpace0: $ed6400 - $ed643f
Pci Device 3:
VendorID: $10ec
VendorName: Realtek Semiconductor
DeviceID: $8139
DeviceName: RTL-8139/8139C/8139C+ 10/100 Mbps Fast Ethernet NIC
ClassCode: $20000
RevisionID: $10
InterruptPin: 1
SubsystemVendorID: $149c
SubsystemID: $139a
IOSpace0: $ed6800 - $ed68ff
MemSpace1: $84010000 - $840100ff
RomSpace: $84020000 - $8402ffff
Pci Device 4:
VendorID: $1002
VendorName: ATI
DeviceID: $5960
DeviceName: RV280 Radeon 9200 Pro
ClassCode: $30000
RevisionID: $1
InterruptPin: 2
SubsystemVendorID: $18bc
SubsystemID: $891
MemSpace0: $90000000 - $9fffffff
IOSpace1: $ed6c00 - $ed6cff
MemSpace2: $84030000 - $8403ffff
RomSpace: $84040000 - $8405ffff
ShowConfig report:
PROCESSOR: CPU 68060/68060fpu/68060mmu
CUSTOM CHIPS: AA PAL Alice (id=$0023), AA Lisa (id=$00F8)
VERS: Kickstart version 40.68, Exec version 40.10, Disk version 45.5
RAM: Node type $A, Attributes $5 (FAST), at $1000000-$4FFFFFF (64.0 meg)
Node type $A, Attributes $2005 (FAST), at $92000000-$9FEFFFFF (223.0 meg)
Node type $A, Attributes $2005 (FAST), at $82C02C00-$82FFFFFF (~4.0 meg)
Node type $A, Attributes $703 (CHIP), at $1000-$1FFFFF (~2.0 meg)
BOARDS:
Board + ROM (HD?) (unidentified): Prod=8738/35($2222/$23) (@$EA0000 128K)
Board (Index Information Ltd): Prod=2206/60($89E/$3C) (@$EC0000 128K)
Board (Index Information Ltd): Prod=2206/188($89E/$BC) (@$200000 8meg)
Avail report:
Type Available In-Use Maximum Largest
chip 1923416 169640 2093056 1915112
fast 275878000 29246352 305124352 233832416
total 277801416 29415992 307217408 233832416
Run >NIL: C:-DRAP
:blink::lol::lol:
You may want to edit your post and put all that between #CODE tags to get rid of the smilies...
Code:
tv.vhi - file N/A
startup-sequence:
; Startup-Sequence for AmigaOS 3.9 + AmiKit (by Jan Zahurancik ©2005-200:cool:
C:stack 8192
Run >NIL: C:-DRAP
if WARN
EndIf
C:morelibspace
C:mcpramlibpatch
Run >NIL: C:wbm
;BootScreen
;C:Wait 5
;C:CyReq
C:BlazeWCP
C:Version >NIL:
FailAt 21
C:FBlit
C:FText
IF NOT WARN
ENDIF
ENDIF
ENDIF
ENDIF
ENDIF
ENDIF
ENDIF
ENDIF
SetENV bbfix 1
EndIF
EndIF
IF WARN
EndIF
IF WARN
EndIF
C:CPU60 B >NIL:
Assign FONTS:
EndIF
C:Mount >NIL: DEVS:-DOSDrivers/~(#?.info)
;C:LoadMonDrvs
; EndIF
Execute T:M
C:-Delete >NIL: T:M
EndIF
;C:P96Refresh
UnSet Workbench
UnSet Kickstart
;C:AfA_OS_Loader
;ENDIF
C:IPrefs
C:ConClip
; C:CyberBugFix
;EndIF
ENDIF
EndIF
EndIF
ENDIF
IF NOT WARN
C:Copy >NIL: ENVARC:SYS/def_RAM.info RAM:-Disk.info CLONE QUIET
ELSE
C:MakeLink >NIL: RAM:-Disk.info ENVARC:SYS/def_RAM.info SOFT
ENDIF
ELSE
C:LoadDB SIMPLEGELS
EndIF
EndCLI >NIL:
PciInfo report:
Pci Device 1:
VendorID: $121a
DeviceID: $5
ClassCode: $30000
RevisionID: $1
InterruptPin: 2
SubsystemID: $57
Pci Device 2:
VendorID: $1274
VendorName: Ensoniq
DeviceID: $5000
ClassCode: $40100
RevisionID: $1
InterruptPin: 3
SubsystemID: $4c4c
Pci Device 3:
VendorID: $10ec
DeviceID: $8139
ClassCode: $20000
RevisionID: $10
InterruptPin: 1
SubsystemID: $139a
Pci Device 4:
VendorID: $1002
VendorName: ATI
DeviceID: $5960
ClassCode: $30000
RevisionID: $1
InterruptPin: 2
SubsystemID: $891
ShowConfig report:
CUSTOM CHIPS: AA PAL Alice (id=$0023), AA Lisa (id=$00F:cool:
BOARDS:
Avail report:
Okay have rebuilt from scratch, the screen switches over (the RTG screen goes black) and the native display remains black.
Using Picasso96 2.1b now as it apparently 100% compatible with the Voodoo driver.
Have installed the latest UP CD from Elbox.
I'm using pci.library v10.
Does anyone have a working Voodoo/Radeon setup? Perhaps I'm missing a tooltype?
---------- Post added at 09:05 ---------- Previous post was at 09:04 ----------
@RichyV - Thanks :-) Will use it to post an updated report once I'm back on the Amiga.
---------- Post added at 09:25 ---------- Previous post was at 09:05 ----------
Code:
RadeonMem = Not Set, previous setting: Not Set
FastEthernet.device - ver.1.25 (7024 bytes)
tv.vhi - file N/A
spider.device - file N/A
DriveSpeed - file N/A
W3D_Picasso96MU.library - file N/A
W3D_AvengerBEMU.library - file N/A
W3D_AvengerLEMU.library - file N/A
W3D_Picasso96M.library - file N/A
W3D_AvengerBEM.library - file N/A
W3D_AvengerLEM.library - file N/A
AmigaOS ROM Update - ver.44.57 (321768 bytes)
Picasso96API.library - ver.2.310 (24520 bytes)
ahi.device - ver.5.6 (58416 bytes)
68040.library - ver.60.0 (392 bytes)
68060.library - ver.60.10 (64632 bytes)
startup-sequence:
C:stack 8192
PsdLoadModule DEVS:input.device QUIET ;Added by Poseidon-Installer
C:DRAP
C:RemApollo QUIET
C:morelibspace
SetPatch NOROMUPDATE QUIET
BootScreen
;C:CyReq
;C:BlazeWCP
C:Version >NIL:
FailAt 21
;Assign >NIL: System: Amikit:
C:CPU60 B >NIL:
Run >NIL: C:CopyMem060
Run >NIL: C:wbm
C:FBlit
C:FText
C:LoadMonDrvs
UnSet Workbench
UnSet Kickstart
C:IPrefs
C:ConClip
;  C:CyberBugFix
;EndIF
ENDIF
EndIF
EndIF
IF NOT WARN
ELSE
ENDIF
;WBCtrl IMT=FAST MNL=100                                         ;tweaks Workbench
ELSE
  C:LoadDB SIMPLEGELS
EndIF
EndCLI >NIL:
PciInfo report:
Pci Device 1:
   VendorID: $121a
   DeviceID: $5
   ClassCode: $30000
   RevisionID: $1
   InterruptPin: 2
   SubsystemID: $57
Pci Device 2:
   VendorID: $1274
   VendorName: Ensoniq
   DeviceID: $5000
   ClassCode: $40100
   RevisionID: $1
   InterruptPin: 3
   SubsystemID: $4c4c
Pci Device 3:
   VendorID: $10ec
   DeviceID: $8139
   ClassCode: $20000
   RevisionID: $10
   InterruptPin: 1
   SubsystemID: $139a
Pci Device 4:
   VendorID: $1002
   VendorName: ATI
   DeviceID: $5960
   ClassCode: $30000
   RevisionID: $1
   InterruptPin: 2
   SubsystemID: $891
ShowConfig report:
RAM: Node type $A, Attributes $505 (FAST), at $1080420-$4FFFFFF (~63.5 meg)
 Node type $A, Attributes $2005 (FAST), at $82C02C00-$82EFFFFF (~3.0 meg)
 Node type $A, Attributes $2005 (FAST), at $90000000-$9FFFFFFF (256.0 meg)
BOARDS:
Avail report:
chip    1320088    772968   2093056   1187896
fast  318580536  19572904 338153440 268435424
total 319900624  20345872 340246496 268435424
If someone can post their settings for the voodoo and radeon monitor's ;-)
So close, very frustrating.
Also, try disabling your USB stack before running a game. I need to disable it on my machine or else I get the same issue (I use Poseidon with a Deneb).
Doesn't happen with all games, for example R-Type will run, but other games don't.
Cheers
Mark
Thanks Mark, yeah I have the Roadshow TCP stack and Subway disabled using the whdload-startup/cleanup scripts :-)
Which works great with the Voodoo disabled.
I can have the Voodoo disabled and still see the extra RAM from the Radeon and WHDLoad works fine.
As soon as I use the Voodoo bam back to black screens. Although SWIV/Silkworm/Nexus 7 Demo work fine LOL.
Going to run snoopdos again and post the result when WHDLoad runs, maybe that will help :-)
---------- Post added at 09:35 ---------- Previous post was at 09:17 ----------
So the only difference I can see between the working games and those that fail is:
Working game:
FindPort lowlevel.library OK
Failed game:
FindPort lowlevel.library Fail
I've given up on this ;-) So my workaround is to switch to an AGA screenmode and use WHDLoad and then switch back to using the Voodoo RTG for everything else.
Rather play games than spend anymore hours on this, wasted a good 3 weeks off and on.
Thanks for the help though, it's much appreciated.
Just an update on this, I've managed to get it switching fine except when it switches back to RTG the Amiga locks up.
So three fingered salute and then start again. :-)
Try to run your Apollo under 70mhz.
When I was running my blizzard 060 over 70mhz I had many problems with the mediator and RTG : software failure, graphics were corrupted, random freezes...
At 70mhz everything was stable.
Hmm will have to source a slower crystal.
It's only when I exit a game now, workbench will freeze. It will switch to AGA/native display fine which it wasn't doing before.
I don't get any corrupt graphics or freezing while playing games with WHDLoad + Voodoo.
I removed everything from startup-sequence/user-startup and WBstartup but still does it.
I'm slowly working through using PVS etc disabling/enabling items so will see how that goes.
i dont have any problems with mine from 80-100mhz.
i suspect its something other than the accelarator.
That's what I was thinking. Tried running snoopdos but because workbench freezes I can't see whats happened.
I do notice that I don't see any pop-up errors from WHDLoad, but I still get error pop-ups elsewhere in Workbench.
Thought it might be MCP but removing that hasn't changed much.
Might try and get WHDLoad to do an error log :-)
