Closed WANTED EXTERNAL SCSI CASE OR scsi cdrom
  • Thread starter Thread starter jvdbossc
  • Replies Replies 2
  • Views Views 1367
jvdbossc
HypnusBE
Belgium
Antwerp (province)
I am looking for an external case that can connect to this : (to the external connector)
http://cgi.ebay.co.uk/Phase5-CyberS...%2BUFI&otn=10&ps=63&clkid=7788738965480315039
So an external scsi case for a cdrom is needed, it can be one with a broken cdrom, since I have a plextor cdrom to replace it if needed.
I am just going this route since my A4000 would have no internal air :Doh:left, if I put a cdrom in it.
Ideally it has the right connector / cable
Open for offers. 15-16-17-18-19 feb will be on holiday, so nut sure can PM then. (just putting this in to inform)
Is that a 50 or 68 pin connector ?
I have cable that connect either to the more common 50 pin centronics ("scsi 1") connector, not pictured. Also have a 50pin to 25pin scsi adaptor (second picture), which allow to use the more common "apple-scsi" cable.
Also have 2 cases from an apple cd300 (first picture), one weighs in at around 1.6 Kg when empty. These are for one scsi cdrom.
Also have a external scsi case for 4 cdrom drives (dont know the weight off hand) no picturers
And one for 8 cdrom drives, this last one weighs 10kg and has 3 independant switching power supplies, pictures 3 and 4.
You will also want an external scsi terminator if this case is at the end of the bus (cable and terminator in 5th picture).
parcifal
parcifal
Parcifal, looking for full kit if possible, yes pic 2 show's the male for my female. One cdrom should be enough.
So probably:
The convertor
A cable
A small case to put in a cdrom
txs, will PM to ask you how much $$$$
---------- Post added at 17:40 ---------- Previous post was at 17:38 ----------
going to pm with parcival interested.
