What monitors are compatible with the Amiga 1200?
boyo
Warwickshire
Are there any 19" or 21" monitors that are compatible without a scan doubler etc?
AmiNeo
CodeMonkey
Kendal, Cumbria
This is a good, nay VERY good question. I'll be following this thread closely (y)...
:popcorn:
HonestFlames
Shropshire
I don't know of any 19's or 21's, but a friend of mine had (still has, in a loft he says) a 17" monitor which handled 15KHz modes with no problem.
Well, no problem except that the gap between each scanline was quite pronounced. Not a fault, just an unavoidable side-effect of dividing up quite a large screen into only 256 lines. Any 19 or 21" CRT capable of handling 15KHz modes will make this problem quite bad.
I set up WinUAE on my old desktop a few weeks ago and had the output displayed on my 19" CRT. When displaying original style scanlines, it was a bit of an eyestrain. It was only really usable when they were doubled.
**EDIT**
I tell you what would be a good hack effort: Mashing up an existing LCD's controller gubbins to make it work with those old modes. It surely can't be beyond the realms of possibility?
User1301
Deactivated
Deactivated
S
G
Of course - you "could" use a 19" or 21" LCD TV via the RGB SCART connection which works very well. Limited resolution though.
Normal monitors (better than the Philips and Commodore ones) that can display more resolutions were the 14" / 15" NEC Multisync (which "may" also have been available as a 17" from memory) and also I actually have a wee Acorn monitor which will be going on sale soon that works with the amiga. Not sure about resolutions that it can display though.
LOL - just realised my post wasn't very helpful :oops:
Cheers
John
Justin
these should work
http://www.microvitec.co.uk/
Sharp Aquos LC32LE700UN
Here's a list of RGB 15khz compatible monitors
Size Make Model MaxRes HScan DP VRef
42 Mitsubishi AM-4201R 1280x1024 15.7-64 Khz 1.1 45-120 Hz
42 Mitsubishi MegaView Pro 42 (AM-4201R) 1280x1024 60 Hz 15.75; 20-64 Khz .96 45-120 Hz
37 Mitsubishi MegaView 37 (XC-3716C) 1280x1024 75 Hz 15-39.5 Khz .85 40-120 Hz
37 Mitsubishi MegaView 37 Plus (XC3717C) 1024x768 75Hz 15-61 Khz .85 40-120 Hz
37 Mitsubishi MegaView Pro 37 (XC-725C) 1280x1024 75 Hz 15.75; 24-64 Khz .85 40-120 Hz
37 Mitsubishi Diamond Scan 37 800x600 15-36 Khz 1.1 40-120 Hz
37 NEC MultiSync XP37 (XP3778A) 1280x1024 1524-78 Khz .85 40-120 Hz
37 NEC Multisync XM37 (XM3750A) 1024x768 1524-61 Khz .85 40-120 Hz
35 Mitsubishi AM-3501R 640x480 15-35 Khz 1.0 40-75 Hz
33 Mitsubishi MegaView 33 (XC-3315C) 800x600 60 Hz 15-38 Khz .83 40-120 Hz
33 Mitsubishi Diamond Scan 33 1024x768 15-38 Khz .83 40-120 Hz
29 Mitsubishi MegaView Pro 29 (XC-2930C) 1280x1024 75 Hz 15-82 Khz .79 40-120 Hz
29 Mitsubishi Diamond Pro 29 1280x1024 15-82 Khz .79 40-120 Hz
29 Mitsubishi MegaView 29 (AM-2725A) 640x480 66 Hz 15-39 Khz .76 45-100 Hz
29 NEC MultiSync XM29 (XM2950) 1024x768 15-50 Khz .75 40-100 Hz
29 ViewSonic ViewSonic 29 GA 1280x1024 60 Hz 15-64 Khz .75 45-160 Hz
28 Aydin Controls Spectrum Autosync 9026 800x600 15-38 Khz .74 50-90 Hz
27 Mitsubishi AM-2752A 640x480 15-39 Khz .76 45-100 Hz
27 Mitsubishi AM-2752 640x480 15-39 Khz .76 45-100 Hz
27 NEC MultiSync 4PG 1024x768 15-50 Khz 40-120 Hz
27 Sony PVM-2530/BS 640x200 15.734 Khz .73 59.9 Hz
26 Mitsubishi Diamond Pro 26M (HC3505SK) 800x600 15-38 Khz .31 45-90 Hz
24 Image Systems M24LV-65MAX 1280x1024 15-80 Khz NA 55-90 Hz
21 Image Systems C21LV-65MAX 1280x1024 15-80 Khz .29 55-90 Hz
21 Image Systems M21LMUMAX 2048x1536 15-65; 48-108 Khz NA 55-90 Hz
21 Image Systems M21LV-65MAX 1280x1024 15-80 Khz NA 55-90 Hz
21 Sony PVM-2030/BS 640x200 15.734 Khz .55 59.9 Hz
20 Aydin Controls Spectrum Autosync 9008 1024x768 15-38 Khz .28 40-90 Hz
20 Mitsubishi Diamond Scan 20LF 800x600 15-38 Khz .31 45-90 Hz
20 Mitsubishi Diamond Scan 20LP (HC3925L9ATK) 800x600 15-38 Khz .31 45-90 Hz
20 Mitsubishi Diamond Scan 20M (HC3925ATK) 800x600 15-38 Khz .31 45-90 Hz
20 Sony GVM-2020 800x600 60 Hz 15-36 Khz .55 50-100 Hz
20 Taxan Supervision 970 640x48060Hz 15-37 KHz .31 50-90 Hz
19 Barco CD-351 1024x768 15.5-23.5 Khz .32 50-60; 72-80 Hz
19 Conrac 7250 1280x1024 15.73-37 Khz .31 Hz
19 Microvitec 1019 800x600 15-36 Khz 40-100 Hz
17 Image Systems M17L-T 1600x1280 15-65/48-108 Khz NA 55-90 Hz
15 Electrohome C15 Series 15 1024x768 15-50 Khz .28 45-90 Hz
15 IDEK / Iiyama MF-5015 800x600 15.5-37 Khz 50-90 Hz
15 IDEK / Iiyama MF-5015A 800x600 60 Hz 15.5-38.5 Khz .31 50-90 Hz
15 Princeton Graphics Multiview II 640x870 15-70 Khz NA 75 Hz
14 AOC CM314 800x600 15-35 Khz .31 50-80 Hz
14 Commodore 1950 (AOC CM314) Up to 800x600 15-35 Khz .31 50-80 Hz
14 Darius TSM-1431 800x600 15.75-39 Khz 50-90 Hz
14 IDEK / Iiyama MF-5014 800x600 15.5-37 Khz 50-90 Hz
14 Magnavox CM1352 640x200 15.7 Khz .42 47-62 Hz
14 Mitsubishi Diamond Scan 14 (AUM-1381A) 800x600 60 Hz 15.6-36 Khz .31 45-90 Hz
14 Mitsubishi FA-3415 800x600 15.7-35.5 Khz .28 45-80 Hz
14 Nanao FlexScan 8060S 640x480 15-35 Khz Hz
14 Nanao FlexScan 9060S 800x600 15.5-38.5 Khz .28 50-90 Hz
14 NEC MultiSync II 800x600 56 Hz 15.5-35 Khz .31 50-80 Hz
14 Panasonic PanaSync C-1391 1024x768 (i) 15.5-36 Khz .31 40-80 Hz
14 Princeton Graphics 1400 (Utra 1400)~A Multisync 15-36.5 Khz 45-120 Hz
14 Relisys RE-5155 800x600 15.5-35 Khz Hz
14 Sony GVM-1310 800x600 60 hz 15-36 Khz .25 50-100 Hz
14 Sony PVM-1354Q 640x200 15.734 Khz .25 59.97 Hz
14 Sony PVM-1351Q 640x200 15.734 Khz .37 59.97 Hz
14 Sony GVM-1311Q 800x600 60 Hz 15-36 Khz .25 50-100 Hz
14 Sony PVM-1390 640x200 15.734 Khz .37 59.97 Hz
14 Taxan Supervision 770+LR 640x48060Hz 15-35 KHz .31 50-90 Hz
14 Taxan Supervision 770+ 640x48060Hz 15-35 KHz .31 50-90 Hz
14 Taxan Supervision 775 640x48060Hz 15-38 KHz .28 50-90 Hz
14 Wen JM143E 800x600 15.75/30-37 Khz .68 48-90 Hz
13 Aydin Controls SP 1499 1280x1024 15-40 Khz .31 40-90 Hz
13 NEC Multisync 3DS 800x600 56 Hz 15.8-38 Khz .28 50-90 Hz
13 Sony CPD-1303 800x600 15.75-35.5 Khz .37 50-100 Hz
13 Sony CPD-1402E 640x480 60 Hz 15-34 Khz .25 50-100 Hz
13 Sony CPD-1302 800x600 60 Hz 15-34 Khz .25 50-100 Hz
13 Sony CPD-1302A 800x600 60 Hz 15-36 Khz .25 50-100 Hz
10 Sony CPD-9000 640x240 15.75 Khz
are these any good? http://www.ambery.com/rgbcgatovgac.html
macwhoelse
Exeter, Devon
Intriguing read.:)
Thought I'd try my 1200 on my Panasonic Viera 42" plasma in the living room.
I had it running through RGB Scart. Picture quality is superb.(y) It is flicker free & looks great. Brings the games to life again !
I had tried it with the same scart cable on my ATEC 37" 1080p. The picture quality wasn't great on the 1080p & I had doubts it was actually seperating the RGB signals, looked like a composite signal.(n)
I had the 1200 on a 1084S previously but may just put the 1084S away for storage.:p
desiv
work in progress...
Salem Oregon
Thanx Juv for the list!!!
It's worth noting that not ALL NEC Multisync monitors are true multi-syncs.
(Well, they do multiple syncs, so technically they are right, but they don't all go down to 15Khz..)
desiv
