Where's the HDD LED connector on this DKB Rapidfire ZorroII SCSI card??
matt020
Finger lickin' good
Western Australia
Yo.
I picked up this DKB Rapidfire ZorroII SCSI card, but it doesn't appear to have a HDD LED connector. Looking at this board, can anyone help me identify where I would plug in the LED connector, or where I would tap in to get a HDD LED working? :unsure:
Zetr0
Ya' Like it Retr0?
Most SCSI drives have an LED (Actvity) driver
check your SCSI Drive Make/Mode/Manufacture and you will get the pinout for the drive.
please keep in mind that those drives that have an LED Activity PIN will be in 5 volts, so DONT connect up an LED directly, you will need a resistor or you will burn out LED.
for 5 volts driving you will need about 15 - 20k resistor pending on the LED.
StrontiumDog
The Willen Lake
The board you have is an eariler revision (revision A) so it might not have had such a connector as standard. The Amiga Resource picture is of a revision C board, perhaps one with optional extra's at the time.
matt020
Finger lickin' good
Western Australia
An update:
Going on Zetro's advice, I googled the SCSI hard drive in my A2000. Turns out it does have an LED plug on the PCB, and it has a built in resistor to wind down the 5volt line.
I soldered the HDD LED directly to the drive, and VIOLA! I now have a working HDD LED on the A2000.
Thanks for the input! All appreciated!
Matt
West Australia.
