Which graphic card for A1200
  • Thread starter Thread starter smaug
  • Replies Replies 28
  • Views Views 1287
Incidentally my Grex setup ran CGX4/Warp3D same as the Bvision but with Voodoo 3 PCI
Just read what is in the .lha of Warp3d v4.2a:
generic] 3330 6472 51.5% -lh5- 44ef Apr 1 2001 Warp3D/Libs/Warp3D/GFXdrivers/W3D_CyberGFX.library
[generic] 16539 40292 41.0% -lh5- b472 Aug 9 2001 Warp3D/Libs/Warp3D/GFXdrivers/W3D_CyberGfx4.library
[generic] 6037 16128 37.4% -lh5- d968 Aug 9 2001 Warp3D/Libs/Warp3D/GFXdrivers/W3D_CyberGfx4_PPC.library
[generic] 4168 10140 41.1% -lh5- 1254 Apr 1 2001 Warp3D/Libs/Warp3D/GFXdrivers/W3D_CyberGFX_PPC.library
[generic] 16077 38664 41.6% -lh5- d3dc Jul 13 2001 Warp3D/Libs/Warp3D/GFXdrivers/W3D_Picasso96.library
[generic] 6331 20508 30.9% -lh5- 8f9b Jul 13 2001 Warp3D/Libs/Warp3D/GFXdrivers/W3D_Picasso96_PPC.library
[generic] 56444 295716 19.1% -lh5- d6a8 Jul 13 2001 Warp3D/Libs/Warp3D/HWdrivers/W3D_AvengerBE.library
[generic] 54450 392596 13.9% -lh5- 69e3 Jul 13 2001 Warp3D/Libs/Warp3D/HWdrivers/W3D_AvengerBE_PPC.library
[generic] 49629 282312 17.6% -lh5- 21f4 Jul 13 2001 Warp3D/Libs/Warp3D/HWdrivers/W3D_AvengerLE.library
[generic] 56017 359436 15.6% -lh5- 743f Jul 13 2001 Warp3D/Libs/Warp3D/HWdrivers/W3D_AvengerLE_PPC.library
[generic] 127751 579708 22.0% -lh5- 55f4 Jul 13 2001 Warp3D/Libs/Warp3D/HWdrivers/W3D_Permedia2.library
[generic] 41918 502980 8.3% -lh5- 722e Jul 13 2001 Warp3D/Libs/Warp3D/HWdrivers/W3D_Permedia2_PPC.library
[generic] 30085 77192 39.0% -lh5- d27d Feb 8 2001 Warp3D/Libs/Warp3D/HWdrivers/W3D_Virge.library
[generic] 19253 53132 36.2% -lh5- 650e Feb 8 2001 Warp3D/Libs/Warp3D/HWdrivers/W3D_Virge_PPC.library
So P96 for Warp3d?
If I still had the hardware I'd be tempted to give it a go! I was always under the impression to use Warp3D with the BVision you needed to go the CGX4 route.
Anyway I fear we've derailed the thread a little lol.
I seem to recall when I put together my recent build of a Prometheus Firebird plus Voodoo 3 then 4. I installed P96 and warp3D 4.2a. The demos worked okay. I know certain demos like “Sulaco” wouldn’t initiate with my PPC Apocalypse. But again that is probably down to not using CGX.
Sorry OP, if this has gone a bit. Just goes to show what a entangled web you can go through 🤣😉👍🏻
Yeah I used P96, Warp3D with Prometheous on an A4k as well as even getting CV64/3D to somewhat work lol
Warp3D works fine with Bvision/CGX4 but I don't think it works with Picasso 96/Bvision as the driver was supplied by Elbox
Edit.
Yeah I've got a PiStorm 32 in my A1200T now in place of the Blizzard, it works with the Mediator (see my project thread) using and old version of Emu68, I've not tried to update it but Warp3D does not work as it needs MMU support which the PiStorm doesn't have currently, for this reason I'm using a Radeon instead of a Voodoo now, more VRAM and runs cooler, can also add Radeon Ram to the system as FastRam
What hardware do you have? I'm trying to get one of the 1200 amigas work to use warp3d but not sure what's best to buy. I'll check your project if I can find it pal. Cheers
Warp3D only works with certain graphics cards such as:
- Blizzard Vision for the Blizzard PPC accelerator (You need Cybergraphx or latest P96 drivers) this will just fit into a tight A1200 standard case.
- Voodoo 3, 4 or 5 PCI cards for Towered system setup’s such as Elbox Mediator 1200 PCI boards. You need older or newer P96 (Formally known as Picaaso96) graphics driver.
- Voodoo 3 or Permedia 2 PCI cards for the old G-Rex 1200 (Tower setup) again with Picasso 96 (P96) driver old or new.
If you have a PPC card that supports Amiga OS 4.1, then I believe the Warp3D setup will work with ATI Radeon 9000 series PCI cards.
For A4000 systems. Then the Zorro-III Phase 5 Cybervision 64/3D cards should work with native Warp3D v4x. Elbox has their own so called tweaked Warp3D V4x for Mediator.
Warp3D unfortunately is not as far as I am aware being worked on and is owned by AEON under license.
